Can you describe the dirt (color, etc.) and where in the pool it is located? Also could you post a set of test results so we can possibly rule out some causes. Remember that there is a lot more turblance in a hot tub so any dirt would remain suspended in the water while in the pool it would tend to settle to the bottom, as Watermom pointed out.
Could you also let us know how you are chlorinating (SWCG, trichlor feeder or floater, liquid chlorine or bleach, etc.) and the type of filter (sand, cart, DE--not sure what you mean by 'filter bags; but suspect you either have a DE filter (the term is 'grids' or 'fingers' depending on design) or a cartridge filter. Also, does your pool have an automation system to switch from pool to spa automatically (and if so what kind) or do you have to manually switch valves?
