Hi,
I am currently planning a pool in north Dallas and I am trying to decide on a way to clean the water. So far I am leaning towards a SWCG system. I was looking into Ozone and UV but decided against those. I guess some of my questions would be are there any materials for the coping around the pool to consider since I am going salt? Any to stay away from? I guess the only chlorine, besides the salt generator, I need to worry about would be for shocking, which I would go liquid.
Filter is going to be cartridge, pump will be variable speed. Interior will be pebble. I am also going to add a slide, aerators, raised spa and the deck will be exposed aggregate to match what we already have and to keep the cost down.
Any input for the planning stage will be appreciated.
Mike
), which, in turn continually raises pH, so be prepared for that. Also, many SWCG systems seem to raise pH as well (not sure why--our resident chemists can explain it better). So you will constantly be compensating for one or both. That's ok, but expect it, and expect to add acid all the time.
