Re: Clear up cloudy water
We have stopped putting any chemicals in other than chlorine, yes we do have a working filter gauge and it does rise while pumping. We are using a test strip type tester and showing little low on chlorine and PH.
As for the filter I'm laughing at myself when I read that it is not a 40# sand filter, I don't know the for sure size of it but it is at least a 21" hayward it took 7-8 50# bags of the filter sand to fill it, The pump is a 1 HP hayward, I will try to get the exact size filter asap!!
Reason: fix smiley
13,900 gal 26 x 4 vinyl AG pool; Hayward 300-400# sand filter & 1hp pump; 'guess-strips'; utility or well water; PF:8.6
26' round 18K gal AG pool; Skimmer tabs; Hayward (takes about 40 pounds of sand) sand filter; Hayward 1 hp lx pump pump; 24hrs; Aqua check 15 second test strips , tests chlorine, ph, akalianty, and stabilizer ; utility water; summer: ; winter: ; iPad; PF:6.7
