Re: Using a 5.5 kw hottub heater to heat a 18ft intex pool?
I can only tell you that you are entirely on your own. These items (donut pool and spa heater) were not designed to work together. The plumbing is incompatible and the electrical bond assumed to be present in a standard pool / spa is not present in an Intex Easy Set. You have to be sure that you don't electrocute your swimmers. The stakes are high when it comes to home-built pool electrical systems.
