Results 1 to 10 of 23
Thread: Fine Tuning a Salt Water Pool
    May 2010
    Default Re: Fine Tuning a Salt Water Pool
    Listen to Mom.
    You don't want to have to lay down by your dog bowl again, now do you?
    I've purchased various chlorine/pH tests over the years but Taylor's K-2006 is, IMO, the very, very best. Its FAS-DPD chlorine test is idiot-proof, accurate and can test ridiculously high levels of chlorine. The others tests are great, as well. If you're like me (a bonafide testing fanatic) consider the 2 oz. reagent size of the K-2006C. Otherwise, the K-2006A will work just fine. Pool stores sell what sells the most -- and most of their customers have no idea what's important so just shop on the basis of price alone. That must be why so few (none in my area) stock the K-2006. Get it on-line, cheap, and be worry-free.......
    16'x29' free-form 14K gal IG gunite pool; SWCG & sodium hypochlorite 8.25%; Hayward SwimClear C4025 cartridge filter; Hayward SP3202VSP TriStar Variable Speed Pool Pump; custom test kit based on Taylor K-2006C; city; PF:8.6
    Quote Originally Posted by polyvue View Post
    l. If you're like me (a bonafide testing fanatic) consider the 2 oz. reagent size of the K-2006C. .
    If you find yourself short on some of the reagents, you can always buy the ones you use most in bigger amounts....that's why I like spspools-spas website.
    sturev's Avatar
    sturev is offline Registered+ Thread Analyst sturev 0
    May 2010
    Heads up on the Taylor 2006 kit from Amato; I ordered mine on Monday and they sent me an email today saying they are out and should be getting some in the next day or so... I'm not sure on the 2006C, they might have that in stock. I'm bummed because it will take a week to get to me once they get it, so I'm stuck with the OTO until then...
    Evan S.
    AG FastLane Pool, 9x13 ~ 3,000 gal, COVERED/INSULATED 23X7, 30 gpm water pump (runs 12 hrs a day) AND a Hayward Power-Flo LX 1.5 hp Pump (only used on occasion for the pool sweep), Hayward 100K BTU Heater, Waterway Flo-Pro Skim Filter & Slime Bag, no other filters
    May 2010
    Listen to Mom.
    NOOOOOO not the "Go lay by your dish" thing! LOL. I'll be a good dog.
    I did a little reading in my faded out instruction sheet in the test kit. The test kit instructions refers back and forth between Total Chlorine and Combined Chlorine as being the same thing.
    I have one of those Testers that says to fill with water and drop a tablet marked #1 into the tester, shake well and read the scale. Then drop one tablet marked #3 into the same solution and compare the readings.
    Well, doing this, I determined that there is no difference.
    Total chlorine and Combined chlorine are not the same thing. TC is the sum of the FC plus the CC. FC is the chlorine that is available to sanitize the water. CC is the chlorine that has already been "used up" sanitizing something in the water. TC is the total chlorine. You want CC to be 0, BTW and therefore, you want your FC to be equal to your TC. (That is kind of a simplified version of each.)
    Kind of funny that that online pool store ran out of kits. (Not funny if you are someone waiting for yours, however. ) What do you bet that Pool Forum had something to do with that lack of available kits! Somebody should tell them they have us to thank for their good business and how about a donation to PF!
    May 2010
    O.K. Mom, to the best of my knowledge, every test I had done whether it was my own feable attempt at pool wizardry or tests performed the pool store said that my Total Chlorine and my Free chlorine were the same reading. I don't know if the pool store ever did a CC test. I assume that the Test Kit you recommend will have a CC test.
    I was a little confused by the instructions in my own kit. If I do the first part of the test using tablet #1, the sample turns a pinkish color and is read on the scale next to the water sample. Here is where I am confused. If I am reading it correctly, it says to put a tablet marked #3 into the pink solution and compare the first reading with the new reading, which will only be readible if the sample got darker. Now, I would have thought that you would start with a fresh sample of water THEN drop tablet #3 into it to compare the reading.
    Now you know how I got my name. Sorry Mom
    Quote Originally Posted by BigTallDumbGuy View Post
    You WANT FC and TC to be the same and in a well maintained pool, they typically are because that would mean that your CC would be 0. But, that is not what you wrote in your post above which I quoted. In that one, you wrote that TC and CC as being the same. Big difference. If your TC and CC are the same, it would mean that your FC was 0 and that would be a BAD thing!
    Make sense??
    BTW -- the test kit will give you the ability to get FC, CC and TC readings with none of the little tablets. It will be a lot easier to use and read.
    Mom
    May 2010
    Make sense??
    Mom
    Nothing makes sense to the BTDG when it comes to swimming pools. Sorry for the confusion. However, the instructions in the lid of the test kit do infact refer to Total Chlorine and Combined Chlorine back and forth as the same thing.
    May 2010
    Missouri
    What Watermom is trying to say is that FC (free chlorine) + CC (combined chlorine) = TC (total chlorine). Combined chlorine is USED UP chlorine--you want this reading to be 0.
    FC (5) + CC (0) = TC (5) --> Here, all the chlorine is Free chlorine sanitizing your pool.
    However, if FC is (2) and the CC is (3), your TC would still be 5:
    FC (2) + CC (3) = TC (5) --> In this scenario, you would have more combined chlorine in your pool than free chlorine.
    Although I've never seen a 'tablet drop' test that you have, I'm pretty sure it won't measure the FC and CC separately; therefore, you are getting a TC reading. A good test kit, as previously mentioned, will provide you with these separate readings and save you a lot of confusion.
    Hope this helps!
    Chris
    OK, here goes. I am not going into the chemistry behind this now but it has been discussed at length here and in other forums but here is how to set up your SWG. Realize that all these points interact so just doing one without the others is pointless. This does work and there are many who can attest that it does! In fact these are the water balance tips for SWGs that are posted on another pool forum that sprang out of this one. However, the groundwork for all this was laid out and documented on here first!
    1) Determine the pump run time you need for proper filtration and turnover in your pool. This can be run as one continuous cycle or broken into smaller cycles. if you break it down make the breaks at even multiples of your cells reversal time (for example, Goldline units reverse polarity every 100 minutes and Pool Pilot digital units have a user selectable reversal time with a default of 4 hours.)
    2) Adjust your cell output to maintain a 3-5 ppm FC with your given pump run tme. (I know this does not agree with the Best Guess chart but this does work with a SWG system and has been documented time and again!)
    3) MAKE SURE YOU ARE RUNNING YOUR CYA AT THE MANUFACTURERS RECOMMENDED UPPER LIMIT! (normally 80 ppm or 100 ppm, depending on the manufacturer). I cannot stress enough how important this becomes to proper pH control!
    If you cannot maintain the FC at the 3-5 ppm range and all the above conditions are met it means your cell is really undersized for your pool. You will need to increase the pump run time. Some manufacturers are more conservative (Autopilot, Goldline) than others (Zodiac) when they rate the gallonage a cell can accommodate!
    4) LOWER YOUR TA TO 80 PPM OR LOWER. Once again, I cannot stress enough how important this becomes to proper pH control! If you have a plaster or fiberglass pool make sure your calcium is in the neighborhood of 350 ppm or higher to maintain 'water balance'. (don't worry, if you follow this you will be 'in the ballpark! )
    5) Adjust the pH to 7.6. (If it is lower than this do nothing, it will climb on it's own--unless, of course it's REALLY low, say below 7.2, then start adding the borax to bring it up!) Monitor it daily until you know your pool. When it reaches 7.8 add enough acid to lower back to 7.6 but not lower. (This is where an acid demand test becomes very useful. The Taylor K-2006 does include this test!) The lower you place the pH the faster it rises! We are trying to minimize how often you will need to add acid while at the same time trying to prevent pH spikes that can cause all types of problems with a SWG pool! Soon you will know how much acid to add and how frequently you need to add it to maintain your pH. Your pool maintenance just got easier!
    6) This step is optional but HIGHLY recommended since it will lower your chlorine demand and further stabilize your pH.
    Add borates to 50 ppm. Once you do monitor your FC because, in many cases you will need to lower your cell output to keep your FC in the 3-5 ppm range.
    You will also find that your pH will comfortably settle around 7.6 to 7.7 for a longer period of time than before and you will need to add acid less frequently and/or add less acid each time!
    I went from about a quart every two weeks to about a cup or so every 6 weeks and have gone as long as 3 months without needing to add any acid to my pool!(fiberglass so it's non reactive,but I have seen benefits in with all pool surface types). I have had customers that have had similar experiences.
    To read a detailed account of my first experiment with this read this thread
    http://www.poolforum.com/pf2/showthread.php?t=4712
    To read the conclusion I came to from the initial experiment (which I have seen repeated time and again in customer's pools and also on other forurms)
    http://www.poolforum.com/pf2/showthread.php?t=5419
    The reason I did thiis was to see if the claims made for Proteam Supreme (expensive borax), Bioguard Optimzier (expensive borax) and Mineral Springs (their expensive salt mix with borax) and Natural Chemistry's Salt Water Magic (another expensive salt mix with borax) were true or not. Guess what, they are true! (and I live in the same town where the original Proteam test pools were located back in the 80s when they were testing this so I have had the chance to talk to a few people in the industry that remember those experiments).
    For a quick update and condensation of the link I posted above, the borates can be added with borax and muriatic acid or by adding boric acid. I have only used the borax and muriatic acid and also Proteam's Supreme Plus which is their pH neutral mix of borax and boric acid.
    60 oz. by weight of 20 mule team borax will raise 1000 gallons of water 50 ppm and requires 30 ounces of 20 baum (31.45%) Muriatic acid to maintain the pH.
    (12 oz. borax raises 1000 gallons 10 ppm and needs 6 oz acid)
    Half the needed amount of borax is dumped into the pool and then half the required acid is then added slowly in the return stream (or diluted in a 5 gal bucket of pool water one or two quarts at a time and then poured into the pool).
    Brush the pool to mix the chemicals
    Add the second half of the borax and the rest of the acid, brush again.
    Circulate for 24 hours non stop then return to your normal pump run time.
    Check pH and borate level in 48 hours. If pH is low but in range you are done, If it is high, lower it to 7.6
    Actually, I have checked my pH and borates about 2 hours of continuous circulation and if the pH is anywhere between 7.2 and 7.8 I have gone swimming.
    For testing borates the LaMotte borate test strip have proven themselves to be superior to all the other strips on the market and provide enough precision to get your borates into the recommended window of 30-50 ppm. I have checked them against the Proteam borate titration test kit time and again they are certainly well in the ballpark! The Proteam test kit is expensive, difficult to find, and not the easiest test to do, btw!
    The AquaChek borate strips are much more difficult to read than the LaMotte and seem to have a much shorter shelf life.
    I hope you find these tips helpful. They do work, but like I said, onl if you do them all and not just pick and choose. Any one of them will help but when done together the results lead to what the SWG manufacturers promise, a pool that practically takes care of itself!
    I hope you find this helpful and if anyone is interested in the actual chemistry then I (and I am sure, chem geek) will be glad to explain it to you. However, just about all of the chemistry info is already here in the forum, much of it in the China Shop!
  1. Pool was fine until we covered it-HELP!!!!!
    By marinemom12 in forum --cleanup--
    Last Post: 11-30-2012, 12:28 PM
  2. Chlorine Pool Water seems like salt water?
    By heatherc in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-08-2012, 04:04 PM
  3. Salt water magic and Intex salt water/copper ionization system
    By enchantedmountain in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-10-2011, 04:37 PM
  4. Salt in a Non-Salt Water pool
    By wollypog6 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-31-2006, 09:01 AM
  5. Fine Tuning Testing Precedure w/ Taylor 2006
    By Gracy101 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-08-2006, 08:36 PM
