Results 1 to 10 of 11
Thread: Hayward Super pump question
    Wisconsin
    Default Re: Hayward Super pump question
    Thanks Al,
    I'll take a shot at it in the morning. Great pic by the way! I'll let you know the outcome.
    LT
    Wisconsin
    Thanks Al,
    That did the trick. It starts right up now.
    LT
    Honesdale PA
    Glad to hear it worked. Another cheap and happy ending. did you wind up dressing the contacts?
    Wisconsin
    Yes I did, but the pump started doing it again. If you start it up when it's still warm, it starts right up. But when it sits for over an hour, then it just humms. I think it's the capacitor, so I'm going to try that next.
    Thanks.
    Honesdale PA
    Could be the cap and they are cheap and worth a try. If it's a loud hum then the cap is shorted. If a low level hum then it's open. You can wedge a piece of paper between the contacts to see what the low level hum sounds like.
    Wisconsin
    It's a low level hum. I put a piece of paper in there, and it still made the same noise. The strange thing is that if I let the pump cycle through 1 or 2 times of not starting, the pump gets warm, and will eventually start. Also, if the pump is warm from being used and you shut it off, as long as it's started before it cools off, it starts up just fine.
    Honesdale PA
    Easy way to do a crude check on a cap is to measure the resistance with a VOM...volt-ohm-milliamp meter. Short the cap terminals first to be sure there is no charge that can damage the VOM. Measure the resistance one way and you'll see the resistance drop low and then rise as the cap charges up. Should eventually wind up high....in the 100K ohm + region. Then reverse the leads and the meter will bang below zero ohms and increase again as you discharge and charge the cap in the reverse direction. This will at least tell you if its open or shorted. VOMs measure resistance by applying a small DC voltage to the device under test, measuring the current and calculating resistance.
  1. Hayward super pump 3/4 ?s
    By Messina1974 in forum Pool Equipment & Operations
    Last Post: 06-27-2013, 10:34 AM
  2. Hayward Super Pump question
    By three4rd in forum Pool Equipment & Operations
    Last Post: 06-14-2012, 12:46 AM
  3. Hayward Super Pump is Super Noisy
    By moneypitpool in forum In-Ground Pool Construction and Repair
    Last Post: 07-25-2011, 10:16 AM
  4. Hayward Super Pump - Super Hot and Shutting Off
    By CapitalBoo in forum Pool Equipment & Operations
    Last Post: 06-18-2011, 09:32 AM
  5. Hayward Super II pump question
    By thefunkie1 in forum Pool Equipment & Operations
    Last Post: 10-02-2010, 08:35 PM
