Thread: Where can I get hold of Richards spread sheet?
    Amir is offline Registered+ Thread Analyst Amir 0
    Potomac, MD, USA.
    Default Where can I get hold of Richards spread sheet?
    Hi Richard,
    I have read your posts. However I can't find your spreadsheet or some of the charts you have posted. Would you be kind enough to post a link to them.
    Regards
    Amir
    Default Re: Where can I get hold of Richards spread sheet?
    Many charts are in the first post or referred to in links to other posts in this thread and the link to the spreadsheet is near the end of that post or may be found here (the link in the post is to a ZIP file while the link I put here goes directly to the Excel spreadsheet). It is NOT for novice users. I use it to calculate pool water chemistry. Michael Smith's BleachCalc that you can find at this thread is much easier to use.
    Richard
    Potomac, MD, USA.
    Thank you Richard.
    Amir
  1. Any Water test result spread sheet or software available?
    By Heavyhook in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-17-2012, 06:35 PM
  2. Will not hold chlorine
    By VetteGuy in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 03-21-2012, 05:11 PM
  3. Can't hold FC
    By nepsa in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-06-2011, 02:47 PM
  4. Cant hold chlorine
    By herrmanncr in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-30-2010, 12:08 PM
  5. Sheet of ice on pool
    By poolboyforjenny in forum Pool Equipment & Operations
    Last Post: 01-11-2010, 11:31 PM
