Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
Thread: Pool Water Chemistry (Warning: Can Get Technical)
    California
    Default Pool Water Chemistry (Warning: Can Get Technical)
    This thread presents my findings so far on pool water chemistry including the following:
    1. More Accurate Calcite Saturation Index (CSI) to replace Langelier Saturation Index (LSI)
    2. Calculation of ppm HOCl (disinfecting chlorine) at various levels of Total Free Chlorine (FC) and Cyanuric Acid (CYA)
    3. Determination of pH and Alkalinity changes when adding chemicals to the pool
    4. Various reaction rates including chlorine breakdown by UV
    Disinfecting Chlorine (HOCl) vs. Total Free Chlorine (FC) and Cyanuric Acid (CYA)
    The most important finding was how little disinfecting chlorine (HOCl) is left after chlorine combines with Cyanuric Acid (CYA) to get "stored" as chlorinated cyanurates (aka cloramides). The chart at the following link shows this relationship. (I recently discovered that all forms of chlorine are measured as ppm equivalents of chlorine gas, so all charts, graphs and the spreadsheet have now been updated to reflect this.)
    HOCl Chart
    Note that the red in the linked chart above represents a cutoff of 0.011 ppm HOCl which roughly corresponds to the 650 mV ORP level that the U.S. and WHO set as the minimum required for disinfection. The green color is a guess at 0.05 ppm HOCl of the minimum level of chlorine needed to prevent algae. The actual number may be quite different, from 0.02 or less to 0.1 or more, but based on Ben's "Best Guess CYA Chart" which is based on real-world experience, I suspect the actual number will be somewhere in this range. So, red means bacterial growth while green means possible algae growth. Blue is the safe area.
    The following shows this same data in graphical form with lines showing the same two (probably correct) "bacteria" and (totally a guess) "algae" levels.
    The following is an approximate formula you can use so long as your CYA ppm is at least 5 times your FC (the formula really falls apart terribly below a ratio of CYA/FC of 3).
    (HOCl as ppm Cl2) = (FC as ppm Cl2) / ( 2.7*(ppm CYA) - 6.6*(FC as ppm Cl2) + 6 )
    and if you are interested in the FC for a given HOCl (to construct the equivalent of Ben's table, for example), you can use the following which just solves for ppm FC from the above.
    (FC as ppm Cl2) = ( 2.7*(ppm CYA) + 6 ) / ( 6.6 + 1/(ppm HOCl) )
    The constants in the above formulas are for a pH of 7.5 (which is the only parameter that significantly affects these constants). With the spreadsheet I can easily calculate the constants for other pH, but remember that the above formulas are approximate. For example, with FC of 3 and CYA of 15 the formula gives HOCl as 0.112 when the correct answer is 0.095. That's not terrible (about an 18% error). However, with FC of 5 and CYA of 15 the formula gives HOCl as 0.370 while the correct answer is 0.199 (about an 86% error) which isn't very good.
    A rough rule of thumb that applies at a pH of 7.5 is that the effective chlorine level is reduced by a factor about equal to the ppm of the CYA. So, a CYA of 30 ppm reduces the disinfecting chlorine (HOCl) level to about 1/30th of what it would be with no CYA.
    The inverse of the above chart may be seen at this link:
    FC Chart
    The chart columns from 0.02 to 0.1 ppm HOCl roughly correspond to "Ben's Best Guess CYA Chart". Ben's chart converted to show HOCl may be found here where you can see that the rough Min FC corresponds to 0.03 ppm, the rough Max FC corresponds to 0.07 ppm (implying an ideal target of 0.05 ppm) and the shock table is not consistent, but probably implies a minimum of 0.3 ppm, at least for green algae. User experience indicates that hard-to-kill yellow or mustard algae (and maybe black algae) may need 1.0 ppm HOCl for shock. User experience with black algae indicates that keeping active black algae from growing requires around 0.07 ppm HOCl.
    A comparison of the "traditional" HOCl/OCl- graph with the same graph in the presence of CYA may be found at this post. This also shows how CYA is a "chlorine (specifically HOCl) buffer" that makes HOCl concentration about half as sensitive to changes in pH.
    The original source for the equilibrium constants was done in 1973 (and published in 1974) where the recommended maximum CYA level was 25 ppm:
    J. O'Brien, J. Morris and J. Butler, “Equilibria in Aqueous Solutions of Chlorinated Isocyanurate”, Chapter 14 in A. Rubin, ed.,
    Chemistry of Water Supply, Treatment and Distribution, 1973 Symposium, (published 1974), Ann Arbor Science, Ann Arbor, MI, pp.
    333-358.
    [EDIT] See document here. [END-EDIT]
    A Little CYA Goes A Long Way
    NOTE: The mechanism of protection of chlorine from sunlight by CYA is currently under review in this thread. Higher CYA levels may protect even proportionately higher levels of chlorine more, especially in deeper pools.
    The following is a graph showing that a large amount of the benefit of CYA protection of chlorine from UV (sunlight) is already there at around 20 ppm. This data is approximate, not only because it is dependent on the amount of sun exposure, but because the rate constants themselves change with FC level (because there is a mix of two different rates of destruction -- one from HOCl and the other from the chlorinated cyanurates which are more stable, but still breakdown from sunlight). The limiting half-life for HOCl/OCl- is 35 minutes which is consistent with pool studies, but some experimental studies give 11.6 minutes. The limiting half-life of the chlorinated cyanurates is 8.4 hours though some other data shows it could be 6 hours.
    The following graph combines the two concepts of needing more chlorine at higher CYA vs. the greater protection of chlorine by CYA. The graph shows the total chlorine (FC) loss rate in ppm/hour vs. CYA at different HOCl levels. Remember that this rate of loss will slow down as chlorine gets used up. Nevertheless, the absolute loss of chlorine is greater at higher CYA levels (keeping HOCl constant) and is the downside to a "high CYA & high Chlorine" approach. However, the primary reason to have higher CYA and Chlorine is to have a sufficient buffer of chlorine to prevent it from dropping to dangerous levels. There is obviously a tradeoff here. Though using no CYA results in the least amount of chlorine loss, the fact is that you simply can't maintain a pool with only 0.05 ppm chlorine everywhere in it -- hence a minimum level is needed as a buffer.
    Salt Water chlorine Generation (SWG) pools seem to require a higher level of CYA, about 70-80 ppm, to operate efficiently. The theory is that the CYA is slow to "store" the chlorine as it is being generated so without enough CYA there is a build-up of chlorine that degrades the performance of the salt cell. I would prefer that the SWG manufacturers offer a larger lower-power (per length) cell that would work efficiently at lower CYA concentrations.
    pH Rising
    If you find that your pH wants to keep rising, this may be due to your pool outgassing CO2 to the air. The rate of outgassing increases with lower pH, higher alkalinity, and aeration of water (splashing, water fountains or slides, high wind, jets pointed up, etc.). The aeration of pool water is a physical process that will vary greatly from pool to pool, but the following chart shows the relative outgassing rate as a function of pH and Total Alkalinity. It is possible that the hydrogen gas bubble production from SWG systems contributes to significant aeration and is a source of rising pH in such SWG pools. The rate is actually a function of Carbonate Alkalinity so this chart is for a CYA of 30, but the variation with different amounts of CYA is not large. Note that there is a large variation with pH (the Y-axis is logarithmic). I have drawn a somewhat arbitrary "Limit" line at a relative rate of 15 that I have found is roughly the tolerance limit where many people start complaining about rising pH, but again aeration is a factor I cannot predict.
    CO2 Chart
    Spreadsheet For Detailed Calculations
    The link to the spreadsheet (in a ZIP file) that calculates all of the above data is PoolEquations.zip and was last updated 29-Jul-2010. It also does some of the things that BleachCalc does, but is not for novice users.
    Also see Equations for Chlorine Chemistry.
    Also see Oxidation-Reduction Potential (ORP) vs. HOCl
    (I will continue to edit this post to add more detail and discussion.)
    Berwyn, PA
    Default Re: Pool Water Chemistry (Warning: Can Get Technical)
    These are great - personally I find I need to stare at them quite a while to grasp them (I guess it's because you're dealing with 3 variables on two-dimensional graphs) but they convey more than words can.
    Just a couple comments / question for clarification:
    --What are the numerical values corresponding to "algae" and "bacteria" on your first graph? Do they correspond to the colors of the numbers in the table (i.e., red is below bact, green is above algae, black is in between)? Do these levels of HOCl correspond to particular levels of "oxidizing power" or "disinfecting power" that we commonly see quoted?
    --Taking that algae line as a given, I read (roughly) the following minimum chlorine PPM for various CY PPM:
    CYA..........Chlorine
    5...........1
    10..........2
    20..........3
    30..........4
    50..........6
    (Could you do another graph or chart which transforms the data into this format?) Unfortunately, these look even a bit higher than Ben's chart - discouraging!
    --On the second graph, would you say the "take-away" is really that most of the chlorine-retention benefit of CYA is *already there* by 20 ppm, rather than "starts at" 20 ppm?
    --The "no CYA" and "infinite CYA" entries are really points, right, not horizontal lines? (Hard to show clearly on this graph, though, I'll agree.)
    --You talk about the "half-life" of chlorine, which gets at a concept you mentioned in that other post and I asked about there. I'm assuming that half-life here means the time in which the free chlorine ppm drops to 50% of what it was before. Perhaps you could also recast this graph to illustrate your point that "with twice as much chlorine, you lose it twice as fast." To me, this emphasizes the "double gotcha" with CYA - it forces you to bring your chlorine levels higher, which in turn means that your chlorine loss each day will be higher.
    Thanks.
    23' x 41' 32k gal plaster circa 1991, 600 gal spa with overflow
    Ultraflow pumps, Titan SS filter, Sta-Rite heater, Polaris 180
    Homegrown X-10 automation -- filter, cleaner, valves, lights, chlorination
    California
    Quote Originally Posted by stualden
    Yes, below the "bacteria" line are red numbers in the chart and above the "algae" line are green numbers in the chart. The "bacteria" line corresponds to 0.011 ppm HOCl which appears to be about 650 mV ORP which is the minimum standard for disinfection in the U.S. and by WHO (though Germany has higher standards). I will add more data to my post to support this assertion, based on the Oregon Commercial Spas Study. However, the "algae" level is a guess since I cannot find good data to determine the level of chlorine needed to inhibit all algae, so I set an agressive level of 0.05 ppm HOCl. The real number could be 0.03 or less, or 0.1 or more, but given that Ben's table is based on reality, the real number is probably somewhere between 0.02 and 0.1 which correspond to the ranges in Ben's table (for the most part -- the shock section is the most inconsistent). I have been in communication with Ben on this and eventually he'll update his tables, but we want to get more real-world experiences from users first -- I plan to start another thread (non-technical) to get such data.
    5...........1
    10..........2
    20..........3
    30..........4
    50..........6
    See my response above. The 0.05 ppm HOCl level I set for "algae" is a guess so don't be distressed by it. Ben's table has low to high ranges that are roughly 0.02 ppm HOCl to 0.10 if you take combinations of "high chlorine & low CYA" to "low chlorine & high CYA". Please do not change any dosing behavior away from Ben's chart unless you are willing to take risks. Though I believe you will be fine from a disinfection point of view, we simply do not know enough about the algae prevention level to make a determination. You also don't want to "run out" of chlorine at any time, so Ben's approach of having a sufficient "buffer" of chlorine (stored in chlorinated cyanurates) is both conservative AND prudent.
    Yes, that is better phrasing and I will edit my post accordingly. Thank you.
    Yes, this is also true. Perhaps I can "truncate" the lines and/or dash them so that they look more like asymptotes which is what they represent.
    This is true, though I'm not sure how to graph this combination. Perhaps I can target a fixed ppm HOCl level and then the graph will show the relationship between FC and CYA that produce that HOCl level. On the same graph I can show the half-life of FC as a function of CYA (so CYA will be the X-axis and FC and half-life will be Y-axes). I'll try something and you (and others) can give me feedback/suggestions.
    Thanks.
    Thanks a million for you comments, questions, and suggestions. I have only just started this post and will add more and hopefully make things clearer. Right now I'm going to add a link to the spreadsheet that is sure to scare the bejesus out of most people! I'll also explain how the HOCl table and graph are only for a pH of 7.5 and will also post approximate formulas for calculating HOCl or FC given CYA levels.
    haze_1956 is offline ** No working email address ** Thread Analyst haze_1956 0
    nj, usa.
    If I understand the first chart correctly.
    Red numbers denote - Level to low to kill bacteria or algae
    Black numbers denotes - no bacteria but algae possible
    Green numbers denotes - algae also killed.
    If this is the case, perhaps you should switch the Black and Green colors.
    A small point I know, but most people will associate the color green with algae growth. And it should help a layman to comprehend the chart.
    California
    Quote Originally Posted by haze_1956
    Yes, you understand the chart correctly. I was thinking of red being "bad" and green being "good", but I see your point that green, in the context of pools, probably means algae to most people. I'll change the colors in the table when I make some other changes I'm working on.
    nj, usa.
    I personally made the "green means algae" association so I mentioned it.
    But now you have me thinking completely in context of pools. How about these for full visual association?
    Red = Germs
    Green = Algae
    Blue = Clean water
    Central Texas
    If the pH is lowered to 7.2 do the charts change significantly?
    CToon is offline Registered+ Thread Analyst CToon 0
    Elkins Park,Pa
    THanks for taking the time to post this information. Having an understanding of the relationships is helpful
    Following the Best Guess Chart has kept me out of trouble to this point. Through real world experience , I know it provides a margin of safety . I also know that things are better when I have FC towards the upper end of the scale. Now there's a little more insight as to how and why.
    Belmont, NC
    This data is very interesting. Thank you for doing this research.
    I downloaded the Excel spreadsheet and began playing with it. Only problem is when I click on the "Calculate pH/TA" button, I get an error message "Compile Error - Can't find project or library". When I click OK, it takes me to the debugger. It highlights "SolverReset" in the "Sub Calculate_pH_TA_FC_CYA()" section of Module1. Any idea what the problem is on my end?
    Thanks,
    Jim
    California
    Quote Originally Posted by aquarium
    I can best describe the change by an example. At a pH of 7.5, FC of 3.0 and CYA of 30.0 (and TDS of 550, Temp of 80ºF), the HOCl is 0.045.
    At a pH of 7.2, with everything else the same, the HOCl is 0.052 which is not a huge change, but is still about a 15% change. The best thing to do is to download the spreadsheet and put in your actual numbers, but remember that except for disinfection, this is VERY preliminary so use with caution. Stick with Ben's best guess chart for now.
    Richard
    Last edited by chem geek; 07-18-2006 at 11:08 PM. Reason: Corrected "22% change" to "15% change" -- what was I thinking?
  1. Using 2006 pool and spa water chemistry book
    By dansdad in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-23-2013, 02:35 PM
  2. New Pool owner water chemistry
    By sammm in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-11-2007, 09:56 AM
  3. Device for Monitoring Pool Water Chemistry
    By CJDahl in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-05-2006, 03:44 PM
  4. Pool is done, water chemistry is getting there too....
    By GTakacs in forum DPD-FAS based testing
    Last Post: 07-18-2006, 11:52 AM
  5. Water Temp & Pool Chemistry
    By cheshamjim in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-23-2006, 03:55 PM
