Results 1 to 10 of 12
Thread: I think my pump might be dead......
Threaded View
  1. #10
    Honesdale PA
    Default Re: I think my pump might be dead......
    This has been mentioned somewhere before. There are no brushes in AC pump motors. The starter switch contacts can get dirty or crudded for a variety of reasons and normally all they need is a cleaning with fine sandpaper or preferrably a thin, flat file. Sandpaper can leave a gritty residue on the contact surface but usually is not an issue. I know some if not most contacts are made of silver which is soft. Silver is also a very good conductor and being soft it tends to 'form' to an irregular surface that results from slight arcing and pitting, thus extending the time between cleaning. Motors with brushes are AC/DC types and are typically used in devices like hair dryers, electric drills, vacuum cleaners including shop vacs, blenders and similar applications where high speed rotation, above 3450 RPM, and/or simple and cheap variable speed control is required. Going back to pump motors, the switch is usually designed so the centrifugal weight mechanism on the rotor does not even contact the switch once operating speed is reached, thus no wear.
    Edit: The oxidation mentioned above can be true for brushed motors. The brushes are a carbon material and the commutator, on the rotor, is copper which is easily oxidized and copper oxide is a lousy conductor of elextricity.
  1. Replacing a Dead Pump Motor
    By Peabody in forum Pool Equipment & Operations
    Last Post: 06-07-2012, 12:46 AM
  2. The pump is dead, long live the pump!
    By maryberrye in forum Above-Ground Pool Construction & Repair
    Last Post: 07-05-2011, 01:38 PM
  3. Dead pump emergency
    By ljh in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-25-2007, 09:32 AM
  4. Left pump out all winter in MO, dead now...
    By Sauce in forum Pool Equipment & Operations
    Last Post: 05-23-2007, 04:22 PM
  5. Dead Pump: How to maintain chemistry?
    By Ken and Laura in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-30-2006, 11:58 AM
