Closed Thread
Results 1 to 10 of 22
Thread: Above Ground pool light
    Port Allegany, PA, US.
    Default Re: Above Ground pool light
    Quote Originally Posted by gwrace1
    I've got two on our AGP. The Aqualuminator and Nitelighter. The AL does a decent job of lighting up our 33' round pool. It also acts as a pool return and came with a nice fountain attachment. I installed a three way valve so I can adjust the flow between the two pool returns.
    I have a return line vacuum, so either I buy the Aqualuminator and the attachement, or I punch a new hole. Also, I have power run to the pump motor, so I was going to just tie into that line. I'm pretty decent at wiring, but I don't know what specfically has to be done to wire these up. Is it just a matter of running through conduit?
    Sacramento, CA, USA.
    As was mentioned above, please only us a 12-volt light in your pool. There are many safety issues involved with a pool light. Also, having power at the pool equipment and having enough power at the pool equipment are two different issues. Make sure that the circuit you plan on using can handle both the light-transformer and the pool filter-pump.
    Quote Originally Posted by thepoolman1
    I should have been more specific. I have two runs of outdoor rated romex, buried in conduit, run to a riser where I plug in the pump. One run is for the pump, one is for two other 60 watt outdoor lights. I am assuming I can just run the 12v transformer from the run for the lights... Is that a valid assumption? The Aqualuminator data sheet doesnt list the current draw of the transformer, which surprises me...
    Covington, LA
    anyone used the new Aqua Luminator color (LED) light. are they bright?
    Thanks,
    Rocket City, AL, USA.
    According to the NEC 680, a pool light MUST be on a dedicated circuit, not on the pump circuit, and not on an auxiliary circuit.
    I have an ABG, and I have three GFI breakered circuits for the pool. One for the pump, one for my Aqualuminator (which we love), and one for the auxiliary outlet and area lighting circuit.
    Do NOT plug in your Aqualuminator or other pool lighting into your auxiliary circuit.
    More info can be found in this thread.
    Covington, LA
    Ok, i got the nitelighter light but i think i need two it only really lights up one end of the pool. I think i'm going to move it tonight to the middle of the wall and see how it looks there. too bad they don't make any lights higher than 50watts for above ground pools.
    Covington, LA
    moved the light to the middle wall (15x30 pool) it made a big difference so i guess i can live with just one light
    Jul 2006
    Morris Il
    I have the nitelighter 35 watt on my 24' ag pool and am going to get another one probably the 50 watt one. 35 watt only lights qaurter of the pool. They are very simple to install too just pull top rail and tighten 2 screws. I have a dedicated circuit for my lights also.
Closed Thread
  1. CFL Pool Light Conversion & can't seal American Products Pool Light
    By DrBAF in forum Pool Equipment & Operations
    Last Post: 09-11-2012, 11:09 PM
  2. Above ground pool light question
    By LedZepFan in forum Above-Ground Pool Construction & Repair
    Last Post: 06-14-2012, 10:04 PM
  3. In-ground Pool Light Won't Work or Turns Off Sporadically
    By moblaine in forum Pool Equipment & Operations
    Last Post: 07-29-2011, 11:46 PM
  4. pilot light won't light on pool heater
    By packerfan in forum Pool Equipment & Operations
    Last Post: 06-12-2010, 03:10 AM
  5. Pool Light Ground
    By TX78539 in forum Pool Equipment & Operations
    Last Post: 10-29-2007, 10:11 PM
