Thread: Single Speed vs Two Speed
    Houston
    Question Single Speed vs Two Speed
    Is there a difference between operating speeds of pumps and their impact on pool water quality and overall utility expenses?
    Default Re: Single Speed vs Two Speed
    Generally, low speed takes half again as long, to twice as long to cycle the water as high speed, and costs 1/3 as much in electricity to do it.
    That's just generally. Specifically, it may vary.
    Usually, the loss is that it doesn't always move the water as well, so the skimmer isn't as effective. On the other hand, a sand filter seems to work much more effectively on the lower speed, filtering more stuff out.
    I would never be without a 2 speed again.
    Kansas
    Hi
    Someone on this board found this link:
    http://www.poolplaza.com/two-speed-pumps.shtml
    It was very helpful to me.
    Infact here is the old thread from whence it was found:
    http://www.poolforum.com/pf2/showthread.php?t=4363
    ~hoffmans
  1. Pump Speed - Single or Dual?
    By tessaduncan27 in forum Pool Equipment & Operations
    Last Post: 05-23-2013, 10:22 AM
  2. If you run a variable-speed pump at half-speed, does the turnover rate double?
    By famousdavis in forum Pool Equipment & Operations
    Last Post: 07-25-2012, 01:22 PM
  3. Dual Speed or a Variable Speed for a plain Jane pool.
    By Lip Out in forum Pool Equipment & Operations
    Last Post: 03-14-2012, 10:32 PM
  4. 2 speed pump. High speed puts sand in pool?
    By mjs31 in forum Pool Equipment & Operations
    Last Post: 08-23-2007, 06:00 PM
