Quote Originally Posted by Snowymoon
Is there an average normal ppm of chlorine loss?
Chlorine loss is a function of several variables including CYA level, sunlight exposure, and how much work there is for the chlorine to do.
My pool lost about 6 ppm today. Is that normal?
That depends. What is your CYA level?
I had shocked it up to 20 ppm, and it took a couple days to come down to 10. This morning it was about 9, and it was only at 3 when I tested this evening.
Why did you shock (algae, heavy swimmer load?)? If there was much for the chlorine to do (e.g. sanitizing and oxidizing) much of it will have been consumed doing what it's supposed to do.
6 ppm per day is pretty high for "normal" conditions. You probably have no or low levels of CYA and/or your chlorine is battling something. Post a full set of test results and people here will help you figure this out.
