Results 1 to 10 of 17
Thread: CYA not showing yet.
    Heartland
    Default CYA not showing yet.
    We switched to BBB from Pristine Blue 4 days ago. I added about 2 1/2 pounds of CYA from Wal-mart. From reading forum I know it takes a long time for it to dissolve, but I haven't got a reading for CYA yet. Is the normal? We added it through the skimmer.
    Also, we add our chemicals late in the day. Most all of the chlorine burns off each day. But, I think the levels stay good through out the day seeing how we only add chemicals once a day. What do you think?
    We add our chlorine at 9 PM. Readings at 10 PM are:
    FC: 6.5
    CC: <.5
    Ph: 7.5
    TA: 110
    CYA: 0
    I take a reading when I get home from work at 3 PM:
    FC: 1.5
    CC: <.5
    Ph: 7.5
    TA: 110
    CYA: 0
    Should I just stay the course until my CYA begins to register? Thanks, Les.
    prh129 is offline Lifetime Member Widget Weaver prh129 0
    Rehoboth, MA
    Default Re: CYA not showing yet.
    Hi Les,
    I have a 24' round also and it took me about 5 lbs of CYA to get to a level of 30 (although I had a lot of rain and had to drain water out of the pool on several occasions).
    According to the BleachCalc program, it should take 3lbs and 3 oz to bring the CYA up by 30 ppm for 13500 gallons. I usually wait at least 5 full days to test but it looks like you could add at least another 1/2 lb while you're waiting. Retest in 3 days and you should see something by then.
    Peter
    Heartland
    Thanks Peter. One thing I've learned: In Oklahoma, full sun, 103 degrees, you need ever bit of your CYA or you'll come home and the FC will equal 0.
    DONNIE is offline Registered+ Thread Analyst DONNIE 0
    Jul 2006
    Oklahoma
    Hey Les. How's your water temp holding up in these triple digits?
    Heartland
    My water is sitting at 94 degrees. I put our fountain on when we swim so it feels cooler. I haven't had any luck with the fountain lowering the pool temp, it just makes it feel cooler.
    Tennessee
    Have you backwashed since adding the CYA? What type of filter? If you have a sand filter you may have back washed out if the filter.
    robin640 is offline ** No working email address ** robin640 0
    Quote Originally Posted by les_smith
    FC: 6.5
    CC: <.5
    Ph: 7.5
    TA: 110
    CYA: 0
    FC: 1.5
    CC: <.5
    Ph: 7.5
    TA: 110
    CYA: 0
    Please tell me the name of the CYA product you can purchase at Walmart. My CYA is a bit low.
    Thanks,
    -Ron
    Tennessee
    Ron
    I think what you are looking for is AquaChem Stabilizer.
    AndieP is offline Registered+ Thread Analyst AndieP 0
    Jul 2006
    Oklahoma
    I converted from Pristine Blue a few weeks back and intially I added 4 lbs of CYA. I added it through the skimmer and waited a week to backwash. At the end of the week and even 10 days out I was still showing no CYA. I bought more and added it to a sock and placed it in front of the jet 2 days ago and I'm already getting a little bit of a reading but still under 30. I added some more tonight in the sock to bring it up a bit more.
    Heartland
    I'm using a 200 lb sand filter. From reading the Forum I knew not to backwash the filter after adding the CYA to the skimmer. So, I haven't done that yet. Here is a website showing what I bought from Wal-mart (item I bought is towards the bottom). It's entitled: 4 LB, HTH, Stabilizer & Conditioner, Cyanuric Acid, Reduces Chlorine Loss Due To Intense Sunlight. - Weight 4.0 Lbs. Item#: 61305
    http://www.unclejoes.com/Pool%20Chem...For%20Less.htm
    I think I might backwash and put some in a sock. I've read about that on the Forum, but I thought thru the skimmer would be less of a hassle. Is there a chance that the CYA from Wal-mart is old and not any good?
  1. Pool pump showing a high psi
    By Wakkoguy in forum Pool Equipment & Operations
    Last Post: 07-18-2012, 12:54 AM
  2. No Chlorine showing up!!
    By Preston in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-28-2012, 07:13 PM
  3. Chlorine Not Showing Up...
    By tommypenngotti in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-01-2009, 05:20 PM
  4. Still showing no cya
    By tjcat in forum DPD-FAS based testing
    Last Post: 07-02-2006, 05:41 PM
  5. Help! 911 - algae showing up
    By sw_stupid in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-23-2006, 08:44 PM
