Thread: Yes/No: Sequestering Agent. Switching from Pristine Blue to BBB.
    Heartland
    Default Yes/No: Sequestering Agent. Switching from Pristine Blue to BBB.
    We are switching from Pristine Blue to BBB. From an earlier post I made: http://www.poolforum.com/pf2/showthread.php?t=3187
    I was told not to worry about using a sequestering agent when we convert since we have a 24' AG vinyl pool. I suppose the idea is that vinyl won't stain. But after reading a newer post:
    http://www.poolforum.com/pf2/showthread.php?t=3717
    I'm confused whether we should use a sequestering agent when we convert. I want to switch with as little down time as possible. Could some of those veterans out there clarify this for me? Thanks, Les.
    Default Re: Yes/No: Sequestering Agent. Switching from Pristine Blue to BBB.
    I personally would use the sequestrant--vinyl pools WILL stain just like other pools will. However, I've not had to deal with copper in my water. I'm going to alert mbar (Marie), who is the resident expert (next to Ben, of course!) on metals and staining. I'd go with her advice.
    AndieP is offline Registered+ Thread Analyst AndieP 0
    Jul 2006
    Oklahoma
    I am in the process of switching from Pristine Blue to BBB. Our pool is concerete/plaster but it sounds like the same would apply to a vinyl pool
    Marie has been extremely helpful in getting me going....you might look at my thread and see if it's helpful.
    http://www.poolforum.com/pf2/showthread.php?t=3628
    mbar's Avatar
    Ashland, PA
    I would use a sequestering agent - vinyl pools do stain, although not as easily as fiberglass or gunite. Just to be on the safe side - it won't hurt, and it will bind up any copper that is left from the pristine blue. Sometimes the water just turns a light green from the copper too, and the sequestering agent will stop this also. Please ask any more questions you may have.
    Northeast PA
    Heartland
    Your right AndieP, your dialog with Marie in the link you provided was really good. It really answered some of my questions and I feel I'm ready to go now. I've got the Taylor K-2006C kit and I've been practicing testing ph and TA. I think I've got the hang of it. I'm going to get some sequestering agent to be on the safe side. Thanks everyone for your help.
  1. Switching from Pristine Blue/Copper in Water
    By jman1975 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-24-2013, 01:54 PM
  2. Well Water: Why you DON'T shock BEFORE using Sequestering Agent
    By NWMNMom in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-09-2006, 06:27 PM
  3. Should I use sequestering agent?
    By Amir in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-05-2006, 04:42 PM
  4. Sequestering agent
    By zelmo in forum In-Ground Pool Construction and Repair
    Last Post: 04-22-2006, 01:06 PM
