Re: PristineBlue to BBB?
.65 ppm copper is about the dose you get from a copper algacide at maintenance level (algae preventative, not killing). Before you shock you need to add a sequesterant to the water to deactive the copper so it doesn't color the water or cause staining. Seqesterants will be a necessary addtion to the water as maintenance on a regular basis. Jack's Magic Blue Stuff has a high chelation index for copper so that would be my first choice.
BTW, Pristine Blue recommends 1 ppm copper in the water when it is used as a sanitizer with small amounts of resudual chlorine so there isn't enough in the water right now to have much effect other than to help prevent algae. Pristine Blue by itself will NOT properly sanitize the water even at 1 ppm! There must be a chlorine residual present!
