Results 1 to 10 of 15
Thread: I am a newbie here and with pool
    Default I am a newbie here and with pool
    This is my first pool. Purchased at walmart. 16' x 3 1/3 ft. It came with no help what so ever. I know absolutely nothing about pool care except for what I have read here, and read in my start up kit, purchased seperatly. The new pool is Intex above ground vinyl pool. I am not sure on the gallons, but I think it is closet o 3500 ? Does that sound right? I started it up with 5 of the clorox tabs, and 5 tblsp of Shock. Is that enough? How much plain bleach can I use from now on, and do I need borax? How much baking soda?
    My ph level is high. According to the test strips. Free chlorine looks good. That is all I know. Havent swam in pool yet. Too cold but sure cant wait. Thanks for the help.
    Sheila
    Default Re: I am a newbie here and with pool
    I forgot to click for answer to be sent to email...sorry..
    duraleigh Guest
    Hi, Sheila,
    Lot's of nice folks here will help you keep your pool clear.
    Your pool is 4,500 gallons.
    Stop back by Wal-Mart and get the HTH 5-way test kit. (about $15) It will test for chlorine, pH, Alkalinity, Calcium and CYA. Post those test results back and folks will help you. Without those results, tho, we'd all be guessing.
    Test strips are just too unreliable to help you (or us) much.
    I'm guessing that the side of your pool is 3.3 ft and the water level is probably 3 ft. Does that sound about right? If that is the case, your volume is more like 4500 gallons. We really need some testing result numbers to be able to help you. Test strips are not very accurate and we don't have much faith in them. Go to Walmart and buy the 5-way drops based test kit and then post your results here. In a pool this size, every 2 cups of plain, unscented 6% bleach will raise your chlorine level by about 1.5. I don't know what clorox tabs are. What type of shock did you use? Post back with more info and someone here will try and help you get started. Welcome to the forum.
    EDIT - looks like Duraleigh posted while I was typing. It seems we have about the same idea, though.
    Hi and thanks for the quick reply. I am using Aqua Chem 1 " stabilized Tablets
    active ingredients trichloro-s-triazinetrione available chlorine, 90%
    then the shock is aqua chem shock plus which says sodium dichloro-s-triazinetrione 3.5 tsps per 500 gal. of water.
    I will go to walmart probably on Mon to get the test kit. Will reply back. In the meantime, I hope my pool does not get covered in algea. Took 4 days to fill it, and would hate to have to drain it and start over.
    It looks like red substance on the bottom is trying to form? I do not know... I went out and swept it.
    Thanks again.
    thanks !!! I have to buy the kit though to tell where the level is at. I have the strips that just say ok, or low or high. Going to try to go to walmart later. Or send dh. Thanks so much everyone.
    OK, You started at the right place!
    I hate to tell you this but you won't be using those tri-chlor tabs too long. They will saturate your water with Cyanuric Acid, aka, CYA,aka Stabilizer. In your WalMart test kit you can test for CYA--when it's 30ppm you are good, when it reaches 50ppm, you need to stop using those tabs. They are also VERY acid so plan on using Borax when your pH drops
    Your "shock" is merely Di-Chlor powder. It's not too different than Tri-Chlor tabs, but it doesn't put as much CYA into the water and aren't nearly as acid. I'd almost rather see you chlorinate with that than the tabs. Chlorine is chlorine, but the different chemicals toss in different side effects.
    You CAN (and most of us do) use laundry bleach for your chlorine AND your shocking. It has virtually no side effects--it's that only chlorine system that can say that.
    1 quart of regular bleach will add about 3ppm of FC to pour pool. (generally a good amount).
    1 quart of ultra bleach will add about 3.3ppm of Free Chlorine (FC ) to your pool.
    All shocking is, is raising chlorine levels to burn off stuff. "Shock" is really a verb in pool care, not a noun. There is no such chemical as "Shock"--it's just hype for various types of chlorine salts.
    We used and loved our Intex EasySet 15'x3' donut for 3 years. I learned SO much on it!
    And, I guarantee you, on a hot day, laying back in a floating lounge chair with a cool drink listening to the ball game or fav music, it's JUST as nice as floating in the fanciest pool in the world!
    Go to these stickies and read them--they will help I hope:
    http://www.poolforum.com/pf2/showthread.php?t=1113
    http://www.poolforum.com/pf2/showthread.php?t=365
    http://www.poolforum.com/pf2/showthread.php?t=1652
  1. Pool newbie
    By Limeybiscuit in forum Pool Equipment & Operations
    Last Post: 03-27-2017, 12:20 AM
  2. Pool Newbie
    By blazin in forum --cleanup--
    Last Post: 10-20-2012, 12:04 PM
  3. Pool Newbie
    By warren_tax in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-18-2012, 05:15 PM
  4. Newbie needs help with pool closing
    By ReelNut in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-10-2010, 09:10 AM
  5. Newbie with a Fox Pool...
    By mariner09 in forum Pool Equipment & Operations
    Last Post: 06-13-2006, 12:08 PM
