Results 1 to 3 of 3
Thread: Hi! New user here with Ecostar problem.
    Nov 2018
    florida
    Default Hi! New user here with Ecostar problem.
    Sooo. I purchased a Haywood ecostar sp3400vsp from some fella on offerup for 20$.. I figuresd its worth the risk of 20 bucks. he said he didnt think anything was wrong with it, so why not.
    This is my first variable speed pump. Figured I'd hook it up on the bench, just to see if the motor would spin. The screen works flawlessly. it says the pump is running, but the motor is not turning. No noise... nothing happens. The digital screen works flawlessly, No error messages. Any ideas?
    Im thinking of direct connecting the motor just to bypass the controls, and see if the motor will start.
    FYI...The motor will turn manually if I use an allen wrench to turn the shaft.
    Thanks all and I appreciate any help you may have.
    Default Re: Hi! New user here with Ecostar problem.
    Sorry, but I'm afraid you got what you paid for. I don't have any advice for you, except that you shouldn't believe people who tell you that nothing's wrong with the $1,000 pump they are selling you for $20.
    https://www.amazon.com/Hayward-SP340.../dp/B004TS04WI
    Good luck!
    The forum is currently only minimally active. Your best bet, if you still need info is to use the Super Search page, to create special search links will allow you to search PoolForum. A phrase like "[]" may produce answers you're looking for.
    Upgraded membership and moved thread to the Equipment section. You may need to log out and back in to see everything.
    PS.You can search use Google to search multiple pool sites, using Google's 'advanced search operators" to limit your search to specific sites. This page of mine will create the search links for you. Google knows my site -- and all the others -- much better than those sites internal search functions! And, if you need to post pictures -- of your pool, filter, pump, piping, what-not -- there are instructions on this page
    Please note: the Super Search page does NOT search directly; it only CREATES special Google links, that enable a FOCUSED Google search!
  1. Hi New user with renovation problem?
    By jack51 in forum In-Ground Pool Construction and Repair
    Last Post: 06-06-2014, 10:19 PM
  2. New ecostar vsp shakes my plumbing
    By jwilliamg in forum Pool Equipment & Operations
    Last Post: 03-29-2014, 06:00 PM
  3. Electronic Problem with Ecostar VSP Pump
    By Gunnerdad in forum --cleanup--
    Last Post: 10-03-2012, 07:04 PM
  4. Hayward EcoStar settings
    By willeyaz in forum Pool Equipment & Operations
    Last Post: 07-31-2012, 08:11 PM
  5. New user First Post Pool Info and a big problem.
    By helnick in forum In-Ground Pool Construction and Repair
    Last Post: 07-09-2012, 12:02 AM
