Help
Remember Me?
Forum
FAQ
Calendar
Forum Actions
Mark Forums Read
Quick Links
View Forum Leaders
What's New?
Advanced Search
Forum
Porcelain Tile for waterline
FAQ
register
Thread:
Thread Tools
Show Printable Version
Email this Page…
Subscribe to this Thread…
Display
Switch to Linear Mode
Switch to Hybrid Mode
Threaded Mode
Threaded View
10-13-2018
02:20 PM
#3
psycgirl
View Profile
View Forum Posts
--General User--
Oct 2018
Austin, TX
Re: Porcelain Tile for waterline
Thanks! This makes sense. They are doing an expansion joint so I should be good.
Quick Navigation
Top
Site Areas
Settings
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
Forums
Ben's Corner
Forum Q & A
-- Subscriber Posts --
Dealing with Algae & Slime
DPD-FAS based testing
Pool Equipment & Operations
Pool Electronics
Odds-n-Ends (P)
Photo Gallery
Clearance
--cleanup--
The China Shop
General Interest
Practice Forum
PoolSolution Archive
The Hall of Shame
Replacing Multiport Value Pentair 50118200 - Need Purchase Advice
Diamond Brite
Advice for replacing tile at waterline
By floridagator in forum In-Ground Pool Construction and Repair
1
Last Post:
03-06-2014,
04:20 PM
Waterline Tile or Not?
By ehorn in forum In-Ground Pool Construction and Repair
5
Last Post:
08-03-2007,
06:18 PM
Waterline tile cleaning
By Sumo1 in forum Pool Cleaning: Manual or Automatic
7
Last Post:
04-16-2007,
02:30 PM
Waterline Tile Replacement
By dave orso in forum In-Ground Pool Construction and Repair
10
Last Post:
07-30-2006,
11:11 PM
Ball Park price for Waterline Tile and Raised bond Beam Tile, and coping installation
By Deal Svengali in forum In-Ground Pool Construction and Repair
0
Last Post:
04-21-2006,
03:59 AM
Digg
del.icio.us
StumbleUpon
Google
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
