Thread: Losing prime on a 60+ year old pool
    Sep 2018
    CA
    Default Losing prime on a 60+ year old pool
    I have a 1950's 40,000 gal gunite pool with on two skimmers (bottom drain closed off).
    I've been able to make it work until recently when it started losing prime. I can get it going but the water level won't stay up. I had the system checked and was told that there were no leaks in the pump/filter equipment so he said it had to be in my 'old lines'. But if it's the lines from the skimmers how would it be drawing air and breaking the prime? They recommended calling a 'leak detection' company who will come out for $500 and tell me where the leak is.
    I just can't see how it could be sucking air from a line that's several feet underground? There shouldn't be a blockage since I've blown out the lines with the shop vac (on blow) and water shoots up out of the skimmers like fountains. Any ideas would be appreciated! Thanks in advance.
    Tanny
    Default Re: Losing prime
    Quote Originally Posted by Tannyj View Post
    With steel pipes, right? I'm amazed you're still able to operate with those.
    Sounds reasonable.
    Happens all the time.
    You've got a leak detector company who guarantees they'll find THE leak (not just a leak or some leaks) for $500? Lucky you! I mean that. Many will just look for leaks, for that price.
    Sorry, but if you've made it almost 70 years with original metal piping, it's not really unreasonable to have to re-plumb the pool. Sorry.
  1. Pump losing it's prime.
    By Phillbo in forum Pool Equipment & Operations
    Last Post: 12-07-2013, 10:43 AM
  2. Losing Prime when vacuuming
    By dbell525 in forum Pool Equipment & Operations
    Last Post: 05-28-2010, 04:32 PM
  3. Pump Losing Prime
    By ChiInSFO in forum Pool Equipment & Operations
    Last Post: 08-08-2006, 03:30 AM
  4. Pump Keeps Losing Prime
    By ellry99 in forum Pool Equipment & Operations
    Last Post: 07-26-2006, 01:00 AM
