Results 11 to 20 of 21
Thread: How do folks backwash?
    Default Re: How do folks backwash?
    It sounds like you are looking for a discussion on the topic; there's probably enough traffic on TroubleFreePool for a discussion. Not sure about PoolSpaForum. You may want to register and post your ? on TFP.
    Jul 2011
    Los Angeles, CA
    Okay - I didn't know about that site. This place is my go-to. Thanks.
    20,000 gallon plaster (concrete) pool
    DE filter
    Nature 2 (unchanged)
    Thanks, but there's a fair bit of traffic here from Google searchers, but very little from registered members . . . so not much new discussion. That's not something that will change before next spring, for a variety of reasons.
    Jul 2011
    Los Angeles, CA
    Hi Ben,
    Can you explain why I should get such a large filter for a 20,000 gallon pool? I'm about to pull the trigger on something.
    DE filter
    Jul 2011
    Los Angeles, CA
    Oh, and because of the DWP rebate program, I'm going to install a Pentair variable speed pump.
    DE filter
  6. #16
    • All filters function better with low flow rates per sft of filter area. This is ESPECIALLY true with sand filters.
    • All filters run longer between cleaning with low flow rates.
    • High flow rates tend to damage filters. High flow = high differential pressure which KILLS filter cartridges, especially modern 'high-capacity' cartridges with pleats that are too close together. High flow may damage DE membrane support grids. High flow WASHES SAND OUT of the filter during backwash, and PUSHES DIRT THROUGH the filter during operation on sand filters.
    • It is still possible to develop high differential pressure, across the media, with oversize filters but it's much less likely.
    Is that enough? If you need more, you'll have to wait till later this weekend.
    By the way, REGARDLESS of filter type or size, you need a WORKING pressure gauge to monitor filter ops properly.
    • NO FILTER should operate at over 30 psi absolute (unless it's the new-ish Pentair high-pressure sand filter).
    • NO FILTER should operate at more than a 7 or 8 psi pressure rise (clean to dirty). Cartridge filters should be cleaned at a 5 psi rise (old style) or 3 psi rise (new style with pleats too close).
  7. #17
    Jul 2011
    Los Angeles, CA
    Thank you.
    If there's more to say, of course I want to know.
    DE filter
  8. #18
    Jul 2011
    Los Angeles, CA
    BTW, I've ordered the recommended filter, the Hayward C3070, and a Pentair Superflo VS. They'll be installed next Friday, September 6th.
    DE filter
  9. #19
    I'll try to get back to this before Tuesday, but I'm glad. I hope it works out really well for you.
    One of the additional reasons for an oversize filter that I hadn't mentioned is the problem of VS pumps. Most of these pumps -- including the Whisperflo VS -- are actually extremely high volume 3HP pumps that can pretty much DESTROY most smaller filters if they are inadvertently run at full speed / full power! They ought to come with a key-locked maximum setting, based on the filter & piping they were matched to, so this couldn't accidentally happen.
    The Pentair Superflo VS is apparently 'just' a 1.5 HP pump (PLENTY large enough for a 20K gal pool!), so the problem is reduced. Even so, that pump can potentially generate nearly 40 psi, if driven against a dirty filter that is undersized!
  10. #20
    Jul 2011
    Los Angeles, CA
    The pump and filter were installed yesterday, and so far they're working very well.
    DE filter
  1. big pool folks?
    By woodhaven in forum Commercial Pool Users, Managers & Workers
    Last Post: 08-20-2013, 11:41 PM
  2. Would you folks even bother??????
    By dansdad in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-22-2013, 09:09 PM
  3. How Often Backwash?
    By ThaSatelliteGuy in forum Pool Equipment & Operations
    Last Post: 06-23-2010, 02:23 PM
  4. How to backwash
    By allison in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-27-2006, 06:34 PM
  5. Backwash - How to?
    By pringlee in forum Pool Equipment & Operations
    Last Post: 06-02-2006, 06:18 PM
