Thread: Chlorine orange; pH high
    Jul 2018
    Louisiana
    Default Chlorine orange; pH high
    I have tried everything. My pool water is clear but it looks green and cloudy. I shocked it, added sodium bromide to reduce PH. I emptied the pool once this yr for the same reason. Help what am I doing wrong?
    Default Re: Ph high and Clorine orange ( after testing)
    1. Assuming you are testing with OTO (yellow drops), an ORANGE result means your chlorine is > 10 ppm. It also means your pH reading is bogus. (High chlorine screws up phenol red)
    2. Did you really add sodium bromide? That's not generally available as a generic chemical. Where did you buy it? What did it look like? What was it called on the box?
    3. What are you doing wrong? I don't have enough info to know:
    + What kind of pool do you have? How much water does it hold?
    + What test kit are you using? What is your stabilizer level?
    + What kind of filter and pump do you have?
    + What chemicals are you using NOW? What chemicals have you added in the last 2 weeks?
  1. Orange color in Chlorine test
    By rkooz in forum Pool Chemistry for Intex-type Pools
    Last Post: 08-23-2014, 11:34 PM
  2. OTO chlorine test is orange . . . for a month
    By Houseofhutch in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-03-2013, 11:49 PM
  3. high cya, high chlorine, is liner safe ?
    By maxhiller in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-05-2006, 04:49 PM
