Results 1 to 8 of 8
Thread: Old Motor Seized Need New Pump
    Default Re: Old Motor Seized Need New Pump
    OK. I looked at your equipment specs. Assuming:
    + 15k gal plaster pool
    + 1.5" ID S-40 PVC piping
    + Pentair 100sft cartridge filter
    I'd recommend a
    + Pentair 340042 SuperFlo 1hp 2spd Pool Pump 230 volt OR
    + Hayward SP2607X102S 1hp 2spd Super Pump 230 vold
    AND a spare
    + Unicel C-7699 Replacement Filter Cartridge
    (if you don't have a spare)
    I've liked the Hayward Super Pump for a long time in this sort of application. But the SuperFlo is designed specifically to compete, and is cheaper on Amazon. Both are 230 volt pumps with a toggle switch, so you do not have install complicated 2 speed pump wiring (which most pool guys, and many electricians can't do!). However, if you don't have a timer, installing one will pay for itself in a year or so, even with a 2 speed pump:
    + Intermatic T104 240-Volt DPST 24hr mechanical switch
    Once you have it all in:
    1. Operate on low speed 8 - 24 hours per day
    2. Use high speed when vacuuming, etc.
    3. Rotate cartridges in and out, keeping a fairly clean cartridge in place.
    Several important points:
    + Both pumps are 240V, not 120V. Make sure you're ready for that.
    + The timer is also a 240V timer.
    + The timer will NOT toggle Hi/Lo, but only On/Off
    + YOU toggle Hi/Lo manually.
    + Dirty cartridges are damaged by large pumps FORCING water through them
    + Clean-ish cartridges work well with low speed pumps; dirty ones, not so much.
    + You should replace the pressure gauge, if is not working.
    =====> Winters SS filled gage w/brass internals, 0-60 psi 2.5" Dial +/-1.5% Accuracy, 1/4" NPT bottom mount
    + If your existing cartridge is shot, you should get TWO need cartridges.
    + Unicel cartridges are OEM quality; discount Chinese cartridges are NOT
    A couple of other things.
    + Pentair models vary. I spoke with Pentair tech support to verify that that specific model has a toggle switch, and does not require special wiring. The support tech was not 100% sure, but thought that OTHER Pentair 2spd SuperFlo pumps may NOT have the toggle. So I'd recommend buying from the link (plus, I get a commission from Amazon).
    + Regardless, you do not want to get into wiring for 2 speed, unless you have a buddy who is an industrial electrician. THEY can do the wiring, right.
    And even though the gauge I linked is a GOOD gage, it still is not freeze proof. If you want a freeze proof gage, that requires . . . well, stuff. I've intended, for years, to assemble and sell freeze-proof gauge sets for commercial pools, but I've never gotten around to it.
    Sunny, Florida.
    I had no considered 2-speeds. Are there advantages to a VS pump vs 2-speed pump? Additional savings?
    What about the warranty for owner installed vs 'professional' ? In particular the Pentair is 60-days vs 1+ years?
    -d
    15K gal. IG Plaster // Mytilus FRP Pac-Fab C-7699 // 1.5" Piping // CENTURY 1.5 HP Motor 3450 RPM 230v (AO Smith) // DOB 1989 // Attached 'SPA' // inline Heat Pump (has not been used for 10 years) with Jandy Diverter Valves // County Water as needed but frequency filled by rain in summer
    The savings from a 2 speed pump is HUGE. In typical installations, on LO, the pump moves about 1/3 of the water with 1/10 of the electricity (3x increase in efficiency) Also, filters function better with LOW flow, than with HIGH.
    VS pumps save a little more, but are more expensive, more complex, and usually work best with electronic pool controls . . . which are ANOTHER point of failure. I'm not a huge fan, for simple pools.
  1. Seized screw/bolt
    By rgshawlf in forum --cleanup--
    Last Post: 03-28-2017, 01:16 PM
  2. Replies: 2
    Last Post: 08-04-2013, 10:37 AM
  3. Replace motor or pump and motor?
    By myLABSpool in forum Pool Equipment & Operations
    Last Post: 05-25-2013, 02:13 PM
  4. One motor primes pump another motor wont????
    By jmurch in forum --cleanup--
    Last Post: 12-17-2012, 11:47 AM
  5. Replace motor or motor& pump?
    By jtcaputo in forum Pool Equipment & Operations
    Last Post: 09-08-2012, 08:27 PM
