Results 1 to 1 of 1
Thread: Matched Pool Equipment Sets: Pump / Filter / Valves / Feeder / [Heater] / [etc]
    Default Matched Pool Equipment Sets: Pump / Filter / Valves / Feeder / [Heater] / [etc]
    ___________________________________
    [ in edit - June 2018 ]
    Matching pipe size to pool volume
    Pipe --- max flow ------ Max pool vol ----- velocity ---- pressure loss
    1.25" ----- 25 gpm ------ 12,000 gallons ----- 5.5 fps ----- 3.7 psi/100ft
    1.5" ------ 35 gpm ------ 17,000 gallons ----- 5.7 fps ----- 3.2 psi/100ft
    2.0" ------ 60 gpm ------ 29,000 gallons ----- 5.9 fps ----- 2.5 psi/100ft
    2.5" ------ 80 gpm ------ 39,000 gallons ----- 5.5 fps ----- 1.8 psi/100ft
    3.0" ----- 125 gpm ------ 60,000 gallons ----- 5.5 fps ----- 1.4 psi/100ft
    Matching SAND filter size to pool volume
    Dia. ----- Area ----- Filter ----- Backwash ----- Optimum ----- Max pool vol.
    18" ----- 1.8 sft ---- 22 gpm ----- 27 gpm ----- 11,000 gallons -- 13,000 gallons
    21" ----- 2.4 sft ---- 29 gpm ----- 36 gpm ----- 14,000 gallons -- 17,000 gallons
    24" ----- 3.1 sft ---- 37 gpm ----- 47 gpm ----- 18,000 gallons -- 23,000 gallons
    30" ----- 4.9 sft ---- 59 gpm ----- 74 gpm ----- 29,000 gallons -- 36,000 gallons
    36" ----- 7.1 sft ---- 85 gpm ---- 107 gpm ----- 41,000 gallons -- 52,000 gallons
    - Sorry, this is going to take a lot more work than I thought. I've done this many times for
    - local customers, but with commercial equipment, which comes with MUCH better
    - engineering data. I was naive to assume what it would be equally easy with residential
    - equipment. Unfortunately, ALL the manufacturers make the relevant data difficult to find,
    - or even unavailable.
    PoolDoc July 2018
  1. Dead heater, remote control, wiring jandy valves
    By jqgreen in forum Pool Equipment & Operations
    Last Post: 08-12-2012, 08:36 PM
  2. Max Distance from Pool to Pump/Filter/Heater
    By barmentr in forum In-Ground Pool Construction and Repair
    Last Post: 06-29-2011, 08:58 PM
  3. Newbie - Please help with pool filter valves
    By medfordman in forum Pool Equipment & Operations
    Last Post: 05-31-2006, 04:48 PM
  4. Remote control for pool heater/equipment
    By Dan6081 in forum In-Ground Pool Construction and Repair
    Last Post: 05-02-2006, 08:57 PM
