Results 1 to 4 of 4
Thread: New user / question about FC test with the K2006
Threaded View
    Jun 2018
    NC
    Default New user / question about FC test with the K2006
    First let me start by saying as a first time pool owner that the Poolsolutions.com site has been a HUGE help for me to get my solid green swamp pool to being able to see the bottom and have what appears to be balanced water! Thank you!
    I believe as a result of running Tri-chlor tabs and shock all last season (that’s what the previous home owner ran and left for me) the stabilizer count is way high CYA @ > 100, I figure about 110-120 based on CYA test in K2006 kit. So I’m running a higher FC count to match the high CYA.
    So this morning I test the FC using the 10ml -0.5 count test and it takes 17 drops, so I figure 8.5 ppm FC, I run the CC test, the sample barely turns red and takes just 1drop to clear so I figure 0.5 CC
    I then rerun the test at the 25ml -0.2 count hoping to get better resolution on the CC results and this time it takes 58 counts to clear! That’s 11.6 ppm !? The CC again just 1 drop so I figure 0.2 CC.
    So the question is what result should I rely on? I did rinse the comparator in pool water between test. Should I average them? Any thoughts would be appreciated.
    I have a 27’ above ground, vinyl liner, 17000 gallon pool running a Pentair 1.5 SPL HP pump and a Waterway Proclean PCCF-125 cartridge filter
    Today’s readings are
    FC 8.5-11.6?
    CC 0.2
    PH 7.6
    ALK 120
    CH 60
    CYA > 100, possibly 110-120
    Thank you for your time
    Bob
  1. First test with my Taylor K2006.
    By Scrapple in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-11-2014, 06:12 PM
  2. Got my new K2006 Test Kit - here is my first reading
    By rdbrya1 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-25-2014, 06:48 PM
  3. First test with k2006
    By Bondo in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-01-2013, 06:28 PM
  4. k2006 test kit
    By fhorta in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-25-2011, 09:46 AM
  5. CYA Test with Taylor K2006 - CYA over 200!
    By ubalr1 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-08-2006, 09:04 AM
