I just had my privacy fence replaced, including a short section that screened my pool pump equipment. Of course, in the process of replacing a fence post, the fence installer managed to bust one of the underground PVC pipes. The pump was turned off at the time as I had added floc the previous evening. When I started the pump, I immediately saw brown water flowing into the pump and the pump lost prime and began cavatating. I shut off one of the skimmers and the pump primed and seemed to run normally. So I presumed there was a break in the suction line from that skimmer, and shut the pump off.
I got the fence guy to pull the post out and dig out the concrete. At that point, I could reach into the hole full of muddy water and feel the break in the suction line. I thought that I could just use a submersible pump to pump the water out of the hole and repair the line. But pool water keeps flowing out of the broken pipe and filling the hole. So I plugged the 2 skimmers and the wall drain (don't have a floor drain), and ran the submersible pump but the water still keeps flowing out of the broken line! I don't understand how this can be unless the suction lines are somehow connected to the return lines?? Next I'm going to try plugging the returns in the pool. As a last resort, I will pump the pool down below the skimmers, wall drain, and returns. Surely this will stop the flow thru the broken suction line, right?
Would appreciate any advice or explanation on how to stop the flow of water thru the broken suction line.
