Thread: Found wrinkles in my liner when I opened the pool
    May 2018
    Illinois
    Default Found wrinkles in my liner when I opened the pool
    Last year, we had a brand new liner installed in our unground pool. It looked great after installation and the duration of the time we swam in it last summer. I opened the pool this spring and discovered big wrinkles (4 of them) across the entire shallow end. They go from the pool steps all the way to the end of the shallow section.
    I tested my pool chemical levels when I closed the pool last year. Everything was okay. I’ve been testing chemicals regularly as I worked to remove the algae.
    What could have caused these wrinkles??
    Default Re: Wrinkles in my liner
    Typically, what happened is that water IN the GROUND got higher than water in the POOL and lifted the liner off the bottom. Then, when ground water level dropped, the liner settled back down . . . but with wrinkles. Unfortunately, the solution involves having pool techs who know how to install a liner, drain the pool and then reseat the liner.
    You'll want to schedule the work now . . . but for warm (hot!) weather. Used liners are less elastic than new ones, and you'll need the heat to get the liner in place without ripping. Fortunately, with a liner only a year old, it should still be possible.
    By the way, you can find answers to questions like this, using my new 'Super Search' page: http://pool9.net/ssearch/. Here's the link it created for "wrinkled liner":
    https://www.google.com/search?q=%28s...0liner+%22+%22
    If you use it, there are a number of other posts and pages discussing this problem, and possible solutions.
    Good luck!
    [ Upgraded membership; moved thread to IG pool construction section => you may need to log in and log out to gain access! ]
  1. Wrinkles in pool liner
    By hope1 in forum --cleanup--
    Last Post: 07-31-2015, 10:43 AM
  2. Got the pool up, beaded liner installed, wrinkles out of the floor, filling and...
    By DennisP in forum Above-Ground Pool Construction & Repair
    Last Post: 09-15-2014, 11:26 PM
  3. Pool Not Opened in 2 Years - Vinyl Liner Stained & Sagging
    By zooba72 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-29-2012, 03:28 PM
  4. Wrinkles in newly installed pool liner
    By heatherwpg in forum In-Ground Pool Construction and Repair
    Last Post: 06-10-2011, 01:31 PM
  5. Wrinkles In AG Pool Liner
    By Catherine_B in forum Above-Ground Pool Construction & Repair
    Last Post: 06-17-2010, 07:26 PM
