Results 1 to 10 of 14
Thread: Tannins in Pool Water?
    May 2018
    Illinois
    Default Tannins in Pool Water?
    Hello! I am from Illinois and recently filled my pool. Right or wrong, I knew that tannins is in the water. But how do I get rid of it? The rest of the water is in pretty good shape (Tested at the pool store), but they were unable to test for tannins. Trying to avoid expensive chemical prices...
    Thanks!
    Default Re: Tannins in Pool Water
    Upgraded membership; moved thread to chemistry problem section => you may need to log in and log out to gain access!
    To start with, "expensive chemicals" won't help with tannins . . . if that's what it is.
    But you need to be sure. Both tannins and iron (and, more rarely, manganese) can turn water brown. Maintaining high chlorine on sunny days will often remove tannis . . . but that same treatment will make iron stains WORSE.
    • What led you to conclude that the water has tannins? Brown water? Brown stains? Somebody said so?
    • What sort of water are filling with? (Municipal, well, surface)
    • Does that water NORMALLY contain tannins? Will this be a 1x or ongoing problem?
    . . . . more info is needed . . .
    May 2018
    Illinois
    Default Re: Tannins in Pool Water?
    Thank you for the response, Pooldoc. The entire village supposedly has tannins. But I think it is just iron. Took a sample to the pool store to have it tested. He said that he has treated many pools from that village. Alkilinity is way high (>250). So he gave us a liquid chemical (super potent). Was told to add 32 oz twice a day for 4 days. Then bring another sample in. After running the pump for 24 hours, I checked the filter and it was orange. This is village water, not well. Rest of the tests were fairly close to acceptible ranges.
    Sounds like iron.
    If you get some of the orange filter waste or goo, put it in a glass with enough water to suspend it, and add either some Vitamin C tabs (ascorbic acid) or some Iron Out. If the water clears . . . it's iron.
    Likewise, if you have an orange spot you can reach, but a few Vit C tabs on it, or a Iron Out paste (in a twist of Saran wrap). Again, if it clears, it's iron.
    May 2018
    Illinois
    Did as you suggested and it cleared it right up... So with that said, should I keep doing the hydrochloric acid (33%)?
    OK. So, you've got iron?
    Post full pool and test info (gallons, pool surface, filter type + test results)
    And, if possible, find out WHERE the iron is coming from. One way to check is -- if your toilet fills with the same water as the pool -- is to check the toilet tank. If the interior is dark orangish-brown . . . you have iron in the fill water. (But, if you have a softener or iron removal filter on the house this won't work.)
    Meanwhile, run the filter 24/7, but make sure the return eyeballs are directed so that water flow is NOT directed against a pool surface.
  1. Pool water green and water 40 degrees
    By Slachey in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 03-21-2016, 11:35 AM
  2. Water turns green when I had water to pool
    By Skymarc in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-10-2015, 09:53 PM
  3. Salt Water Pool Water Smells Like Must
    By desherer in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-28-2011, 01:20 PM
  4. How do I remove the tannins from my pool?
    By WendyO911 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-23-2011, 09:06 PM
  5. got new 24x5 round intex pool need help with water. Sandy water..help
    By iwannaswim in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-08-2011, 08:42 PM
