Results 1 to 3 of 3
Thread: need help choosing epoxy and primer
    angeleyes69 is offline Commercial pool users, operators, owners angeleyes69 0
    May 2018
    usa
    Default need help choosing epoxy and primer
    Have a 14x24 inground pool with concrete bottom and walls of unknown plastic type removed the linning and want to convert to epoxy. Need help choosing the right epoxy and primer that will be compatible with the different materials the pool has. Also what should I do with the gaps between the side panels? Can I fill them with silicone and then coat with epoxy? Also it has a drain in the bottom is there a plug that can be removed i could find no drain pipe and it was getting dark once I got the water drained so I could not really look further. There is still water seeping in from the ground and I assume i have to wait until it is done before I epoxy it. Makes common sense. This pool is for a motel a friend works at so I want to get everything done correctly.i have more questions but will search threads and save them for a late later time. Any help would be much appreciated thans in advance!
    Default Re: need help choosing epoxy and primer
    Sorry, there's very little help I can offer you.
    Here are some quick tips . . . and an explanation:
    1. If you want to use epoxy, go to http://www.kelleytech.com/olympic/ and spend HOURS (literally) CAREFULLY reading their technical guides. And, then follow them. Kelley also has materials for expansion joints.
    But, don't be surprised if you fail. In my area, according the the manager of the local pool wholesaler told me I was the ONLY pool contractor in the area to consistently use epoxy successfully. It's not hard but it is VERY 'picky' work, and VERY unforgiving. You can not 'half-a##' it; you can't ignore the temperature requirements, etc.
    The general rule with epoxy is, unless you are very careful and meticulous, it sticks to everything you do NOT want it to stick to, and comes LOOSE from everything you DO want it to stick to.
    It can be done; I painted about 20 pools of 120,000 gallons or more, all successfully.
    2. But, apart from that you are VERY unlikely to get help online. Pool professionals, and commercial pool operators, appear briefly on forums seeking answers to THEIR problems, and then disappear. They do NOT stick around to help other commercial or professional users. That means there are lots of questions, with no one to answer them.
    Also, for those reasons, there is very little RELIABLE information specific to commercial pools here, or elsewhere. But if you like, you can use my "Super Search" page to look: http://pool9.net/ssearch/
    3. And there's more bad news: just from the way you are asking the questions, I can tell you are not qualified to do the work you are looking at. So, I can't help you either.
    Good luck!
    PS: Your best bet, if you don't want lose a friend? Help him find someone who IS qualified.
    Upgraded membership and put a copy of this thread in the Commercial section, here:
    http://www.poolforum.com/pf2/showthread.php/28997
  1. need help choosing epoxy and primer for commercial pool
    By angeleyes69 in forum Commercial Pool Users, Managers & Workers
    Last Post: 05-22-2018, 01:51 PM
  2. Epoxy Paint
    By ScootersMama in forum --cleanup--
    Last Post: 06-04-2016, 10:28 PM
  3. Help with Choosing the Right Pool
    By dmarino16 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-13-2012, 08:34 PM
  4. Pristiva Primer and Activator
    By cjryan33 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-08-2012, 11:08 AM
  5. Algae - need a primer!
    By heymom1 in forum Dealing with Algae & Slime
    Last Post: 07-03-2007, 10:38 AM
