Thread: Pool Chemicals to Prefer, Pool Chemicals to Avoid
Threaded View
    Default Pool Chemicals to Prefer, Pool Chemicals to Avoid
    ____________________________________
    Pool Chemicals to Prefer, & Ones to Avoid
    Blended chemicals are a nightmare for pool owners: they cost more per unit of 'real' chemicals AND they often add unneeded phosphates or pH buffers causing their own real problems.
    AVOID:
    • Any type of chlorine with "BLUE" in the name.
    • Any type of 'shock' or chlorine described as 4-in-1 or 5-in-1.
    • Arm & Hammer brand pool chemicals
    • Biolab brand pool chemicals
    • Clorox brand pool chemicals.
    • Clorox bleach (often contains additives!)
    • Pool Time chemicals (a Biolab brand!)
    • Pool chemicals sold by Walmart or Costco -- ALL that I've seen are blended.
    PREFER:
    (chemicals for small pools in BLUE)____________________________________
    IMPORTANT: Just because a chemical is preferred, you should NOT assume that YOU need that particular chemical. IF you need it, you'll be better off buying a preferred brand than other wise. But, if you don't need it . . . you don't need it, whatever the source.
    Also, you can sometimes get decent chemicals from non-preferred sources. BUT you have to be very careful to read the label!
  1. Need help with chemicals for 16 x 48 pool
    By Essie1982 in forum --cleanup--
    Last Post: 05-30-2017, 04:41 PM
  2. What chemicals do we Need for New Pool?
    By ssowell in forum Intex-type Pool Setup & Operations
    Last Post: 06-12-2012, 11:12 AM
  3. Chemicals are off in new pool......
    By drdjsmm in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-21-2011, 12:31 PM
  4. Please help with pool chemicals
    By mavswimmer in forum Commercial Pool Users, Managers & Workers
    Last Post: 03-22-2011, 07:16 AM
  5. How/What chemicals to use in pool...
    By drako4 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-25-2010, 05:39 PM
