Thread: Borax Questions
    Pattee33 is offline Commercial pool users, operators, owners Pattee33 0
    May 2018
    West Virginia
    Default Borax Questions
    The pool in question is a Senior Citizens Indoor Heated Salt Water Pool. 20,000 gallons.
    I use a box of 20 mule team borax to help lower my Total Alkalinity. It worked very well. However, a week later, one of the lifeguards thought they had a low PH and another box of borax.
    We started to see some sudsing (for the want of a better term). This occurs about 1.5-2 hours after people are out of the pool. Agitation makes it go back into solution. I did a Saturation index on the water and it checks out good.
    I skimmed off some of the suds and did a PH on it and it was about 8. One pool supply suggested adding dry acid, which I did. Our PH is usually about 7.6 on a daily basis. I also added some enzymes to help with the combined chlorine which has climbed from 0.4 to 0.8
    Sometimes the pool surface is milky which eventually disappears and becomes a little flocculent ( for the want of a better term).
    is it possible that the water is supersaturated with the borax and it is coming out of
    solution?
    Default Re: Borax Questions
    1. Not sure what was added, but borax does NOT cause foaming. Did he add "Boraxo" detergent?
    2. We don't support indoor pools, as a rule. The chemistry is different and much more complicated.
    3. We don't support commercial (ie, non-residential) pools. The chemistry is different, code-regulated and much more complicated. Also, there is public health liability, both morally and legally, when it's done wrong . . . and it almost always is.
    FWIW, I worked professionally with commercial pools for almost 30 years, so I'm not just talking off the top of my head.
    Sorry . . . thread closed.
  1. Borax Questions for Commercial Pool
    By Pattee33 in forum Commercial Pool Users, Managers & Workers
    Last Post: 05-04-2018, 01:30 PM
  2. Replies: 13
    Last Post: 08-28-2014, 04:33 PM
  3. Couple of questions (burning eyes and Borax allergy)
    By TarheelFan in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-30-2012, 07:11 PM
  4. New Pool Owner Questions - 8 questions!! :)
    By kmmlangston in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-30-2010, 04:33 PM
  5. Borax
    By roytyson in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-11-2006, 11:22 AM
