Keep in mind the two most critical pool water values are chlorine level, and pH.
If the pH is between 7 and 8 . . . no rapid damage is occurring, so you've got time to learn more. (Higher than 8 or lower than 7, and you could be doing real damage real fast!)
If the chlorine is above 2 - 3 ppm and the pool is not green . . . you are probably OK. (There are complications that mean there are exceptions.)
The fast and easy way to be sure of these two factors is to get a CHEAP OTO / phenol red test drops kit. Test strips are NOT accurate or reliable . . . and the K2006 we recommend is complicated. So start with the OTO / phenol red, from Walmart or Amazon. The Taylor K1000, from Amazon is preferable. [http://pool9.net/k1000]
You *will* need learn the K2006. But a cheapo K1000 or other OTO kit offers an easy and reliable 'sanity check' while you are learning to use the K2006.
