Results 1 to 10 of 21
Thread: Chlorine tabs w/o CYA
    Default Re: Chlorine tabs w/o CYA
    You may want to consider bumping your CYA up some. Sometimes, people who live places that are very hot and sunny find that having a little higher CYA allows them to dose with bleach less often. One of our former mods lives in NW Louisiana and deliberately keeps her CYA around 80ppm. Just something to think about. If you do decide to raise it some, go to 60 for a couple of weeks and see how that works on your pool and then go a little higher if you want. Gradual increases rather than big changes. Easy to add more CYA, hard to lower it.
    By the way, if you are diligent about keeping your chlorine between the minimum and maximum levels based on your CYA, you should seldom need to shock. Pool stores and pool chemical companies tell you to shock weekly but it isn't necessary. They just want to sell more chemicals.
    Jul 2014
    Tx
    Temps here are starting to drop, so hopefully the chlorine demand will start dropping too.
    Re-checked my CYA yesterday. That test indicated I'm closer to 40 instead of 50, so I do need to bump it up a bit. Just finished dissolving the last bit of solid CYA I had via the sock method. I have some pucks left over so I might as well use them to help bring the CYA up a bit more. Also picked-up a floating dispenser and will throw a couple of pucks in there also.
    I gotta be careful about over-shooting the CYA since replacing a large amount of water is very expensive due to the house being on a low-producing well (gotta truck in water).
    Pool looks great and CC levels are close to zero so I don't see a need to shock yet.
    Thx for all the replies!! You guys are awesome :-)
    IG concrete 30k gal FNS60 DE filter 2hp single speed Haywood pump
    Jul 2014
    Tx
    If you use the trichlor pucks, keep an eye on your pH. They are extremely acidic and will push your pH down.
    No problem with the pucks. I have to add a gallon of acid every 2-3 days anyway. My fill water is very hard.
    @Ben,
    I have a pair of them--had them for years, just for the pool. Home Depot sells them, and Harbor Freight sells a no-name version of them as well. I didn't know they came in sizes!
    I use them on the quick connects, and on the screw-on caps and spigots for the 5 gallon carboys of LC.
  1. Tabs or No Tabs
    By johnway2 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-09-2014, 09:44 PM
  2. septic tabs?
    By lguti69 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-20-2012, 07:59 PM
  3. Bleach VS Tabs
    By samtex in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-14-2011, 02:15 PM
  4. chlor.tabs with cya?
    By fhorta in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-28-2011, 03:44 PM
  5. hth 3 in 1 tabs
    By fish in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-16-2010, 09:23 PM
