Help
Remember Me?
Forum
FAQ
Calendar
Forum Actions
Mark Forums Read
Quick Links
View Forum Leaders
What's New?
Advanced Search
Forum
Test results on new pool in Tucson
FAQ
register
Results 1 to 10 of 155
Thread:
Thread Tools
Show Printable Version
Email this Page…
Subscribe to this Thread…
Display
Switch to Linear Mode
Switch to Hybrid Mode
Threaded Mode
Threaded View
09-09-2014
09:04 PM
#32
Wilco
View Profile
View Forum Posts
Registered+
Thread Analyst
Aug 2014
Tucson
Re: Test results on new pool in Tucson
Yep, calcium hypochlorite, you are correct.
Quick Navigation
Top
Site Areas
Settings
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
Forums
Ben's Corner
Forum Q & A
-- Subscriber Posts --
Dealing with Algae & Slime
DPD-FAS based testing
Pool Equipment & Operations
Pool Electronics
Odds-n-Ends (P)
Photo Gallery
Clearance
--cleanup--
The China Shop
General Interest
Practice Forum
PoolSolution Archive
The Hall of Shame
cyanuric acid test
Conflicting test results...........
Need help w/test results
By The Mermaid in forum Dealing with Algae & Slime
11
Last Post:
10-02-2006,
06:26 PM
More Test Results!
By mkfmedic in forum DPD-FAS based testing
5
Last Post:
09-12-2006,
02:15 PM
Test results vary between meter and drop test - not sure what to do?
By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
14
Last Post:
07-29-2006,
04:27 PM
First 234s test results and warning about pool stores' results
By SoCalBoo in forum DPD-FAS based testing
1
Last Post:
06-16-2006,
02:48 PM
First Test Results
By Cutter in forum DPD-FAS based testing
1
Last Post:
06-14-2006,
08:30 PM
Digg
del.icio.us
StumbleUpon
Google
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
