Results 1 to 10 of 155
Thread: Test results on new pool in Tucson
    Default Re: Test results on new pool in Tucson
    Quote Originally Posted by Wilco View Post
    Ok, but the tabs aren't keeping the cl level up at all. So I quit and went with Bbb method. ( although haven't added the third b yet, not sur when to. TA stays about 80.
    The BBB method is a method, a philosophy, if you will, of only adding what you need, knowing what you need because you test regularly, and not being taken in by pool chem companies' flashy names so they can charge 3x as much for baking soda or washing soda, or "cocktails" of combinations of chemicals which are more a problem. It's not a rigid system--just the opposite. But you don't add stuff "just in case".
    I use Tri-Chlor tabs from time to time--usually in the spring in a floater or two when my CYA is low. I also use Liquid Chlorine instead of bleach because....when I do the math, for me it's cheaper. LC is merely stronger bleach anyway. Mostly though, I use my SWCG for chlorine.
    Borax is one of 3 ways to raise pH. But it's generally the preferred way.
    Baking Soda is when you need to raise TA. I, and others, have found that TA is only a concern when something else is happening. So if your pH is trending down all the time (and it's not from constant Tri-chlor tablet acidity) raising TA can slow it. A constantly rising pH can be slowed by a lower TA, etc.
    Wilco's Avatar
    Wilco is offline Registered+ Thread Analyst Wilco 0
    Aug 2014
    Tucson
    So what do you mean by saying that the trichlor may not be dissolving? I was putting 4 pucks in the floater and they would last a week or so, but I had to add 2 bags do shock in order to notice any testable cl levels. And, as you said, my ph was staying low. Better now using bleach and regular testing. Would using the pucks be am option say if I were going on vacation for a week?
    4 pucks per week equivalent to 1.5 lbs Cl2 gas
    PF=6.7 for 18k gal pool
    So 1.5 x 6.7 = 10 ppm chlorine per week.
    Typical daily use, on a lightly used pool in a sunny area, when everything is running well is 1.5 - 2 ppm per day. 10 ppm is at the bottom end of that.
    IF there is ANY algae, or ANY problems, chlorine use will be more on the order of 4 - 5 ppm per day OR HIGHER. Cleaning up algae can consume 100 ppm of chlorine in just a few days.
    You need to MAINTAIN a chlorine level of 10 ppm (based on your CYA), doing what ever is required to get there. Once the pool is spic and span, you may find that 4 tabs per week (or 2 gallons of bleach) may be adequate to keep it there. But that's not the case, yet.
    Wilco's Avatar
    Aug 2014
    Tucson
    Ok, that was what I was getting to, was the daily demand/loss do cl that could be expected. There was an algae bloom when we first moved in 6 weeks ago, but that cleared up with initial treatment. Water has gained clarity steadily, and looks great now, but maybe the residual of that bloom and the heat here increased the demand quite a bit. Are the hth shocks ( sodium hypochlorite) better for me with presumed high cya than dichlor?
    Wilco's Avatar
    Aug 2014
    Tucson
    Yep, calcium hypochlorite, you are correct.
    Jul 2013
    Northern Illinois
    Oh my. You want a minimum 10 ppm FC (free chlorine) in your pool. You have Tri-Chlor pucks. They add FC but also add CYA and you don't want more CYA. You mentioned Di-Chlor, same thing. HTH shock adds FC but also adds calcium and your CH is high enough. You have used bleach (sodium hypochlorite), which will add FC but not affect CH or CYA. Is there any particular reason you prefer not to continue using bleach?
    Last edited by FormerBromineUser; 09-10-2014 at 12:44 AM. Reason: Added chemical composition of bleach
  1. Need help w/test results
    By The Mermaid in forum Dealing with Algae & Slime
    Last Post: 10-02-2006, 06:26 PM
  2. More Test Results!
    By mkfmedic in forum DPD-FAS based testing
    Last Post: 09-12-2006, 02:15 PM
  3. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  4. First 234s test results and warning about pool stores' results
    By SoCalBoo in forum DPD-FAS based testing
    Last Post: 06-16-2006, 02:48 PM
  5. First Test Results
    By Cutter in forum DPD-FAS based testing
    Last Post: 06-14-2006, 08:30 PM
