Page 2 of 16 FirstFirst 1 2 3 4 12 ... LastLast
Results 11 to 20 of 155
Thread: Test results on new pool in Tucson
    Default Re: Test results
    Why guess? That's why we test.
    Wilco's Avatar
    Wilco is offline Registered+ Thread Analyst Wilco 0
    Aug 2014
    Tucson
    Ok.didnt budge the chlorine level, but brought the cya down to about 40. Smells more chloriney
    Adding bleach cannot drop the CYA level. It would probably be a good idea to watch these testing demo videos:> http://pool9.net/K2006-vid/ and then try your tests again.
    Wilco's Avatar
    Aug 2014
    Tucson
    Maybe apples and oranges, second test was with 6 way strip. Will do full Taylor tomorrow I guess
    6 Way strips do NOT give a good CYA reading. The color in the very center MAY be correct if you're super-careful, but the color of most of the pad usually isn't.
    Wilco's Avatar
    Aug 2014
    Tucson
    Ok.test strip (6 way) foes seem yo consistently show cya of 40-60, while the kit shows about 100. Have hit it w bleach and had cl up to 6 and ph at 7.2. How aften do I need to add bleach generally to keep from porpoising?
  7. #17
    Default Re: Test results on new pool in Tucson
    => CH=380 is not really a problem; just run your TA lower. (http://pool9.net/alk-step/
    => With a high CYA, consider establishing a borate level > 60 ppm. The primary downside of a high CYA is that IF you get algae, it can take extreme levels of chlorine to eradicate it. Adding borates doesn't kill algae, but it does make your pool less susceptible. http://pool9.net/borates/
    => As mentioned, it IS typical to lose CYA over the winter. But you probably want to avoid this. Bacterial decomposition is the reason for this loss, and it can have hard to predict effects. Most often, the CYA is converted to nitrogen gas (no problem!) or nitrates (minor problem). But in a significant percentage of cases, the conversion is to ammonia, which is a big problem, and tends to ruin your spring start up.
    => In Tucson, I'm guessing you plan to run the pool all winter, and leave it uncovered. I'd highly recommend keeping 4 gallons of bleach on hand (stored in a cool place), and dumping all 4 gallons into your pool at the FIRST sign of algae or biofilm.
    Good luck!
  8. #18
    Wilco's Avatar
    Aug 2014
    Tucson
    Ok. Just retested and can't even detect cl levels, and ph down to 7.0. Seems like I will have to pour a gallon of bleach in a day at this rate. Where is all the cl going???
  9. #19
    1. Did you use OTO drops to test?
    2. What time of day did you test?
    3. Regardless: add 2 gallons of bleach in the LATE evening and then test with OTO the following EARLY morning.
    4. Post dimensions (shape, max length, max width, shallow depth, deep depth) AND reported gallons.
  10. #20
    Wilco's Avatar
    Aug 2014
    Tucson
    Yes I used the Taylor kit for test. I then added a box of borax and one bag of shock. Retested an hr later at 4 pm and got ph of 7.2 and cl of 4 ppm. Just seems like cl disappears.
  1. Need help w/test results
    By The Mermaid in forum Dealing with Algae & Slime
    Last Post: 10-02-2006, 06:26 PM
  2. More Test Results!
    By mkfmedic in forum DPD-FAS based testing
    Last Post: 09-12-2006, 02:15 PM
  3. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  4. First 234s test results and warning about pool stores' results
    By SoCalBoo in forum DPD-FAS based testing
    Last Post: 06-16-2006, 02:48 PM
  5. First Test Results
    By Cutter in forum DPD-FAS based testing
    Last Post: 06-14-2006, 08:30 PM
