Results 1 to 10 of 228
Thread: Clear, but no chlorine???
    Default Re: Clear, but no chlorine???
    About Pee in Pools:
    Basically, any kids who were hydrated when the left in the house, and who remain in the pool 2 hours (where they aren't sweating) have probably pee-ed in the pool.
    Dedicated US Swimming participants (year round swimmers) pick up the habit of doing so during 2 hour practices during which they aren't allowed to leave the pool. (Coaches HATE having to retrieve swimmers who are tired and taking an extended break in the rest room.)
    I know it's gross -- till you get mentally adjusted to it. Urine is normally sterile, which is why doctors can test for bladder infections using a simple presence/absence test for bacteria. Consequently, it's not really a health problem. But urine DOES use up quite a bit of chlorine, and it combines rather badly with chlorine at that. On outdoor pools exposed to solar UV, the combination of chlorine + UV destroys the byproducts rapidly. The one place where pool UV systems have a REAL value is on indoor pools where these combination products accumulate in the absence of solar UV.
    But, if you want to keep pee out of your pool, you either have limit pool sessions to 1 hour or less OR provide an EASY alternative. Many homeowners exclude dripping kids from the house: if you do, you also have a pee-filled pool, unless you've worked out an alternative. This can be -- depending on your fences and family's modesty standards -- as simple as a designated pee-bush! Others set up a camping type portable outhouse. Of course a dedicated pool house with a flush toilet is the ultimate solution, but you'll need an extra $20,000 or so, plus enough yard, if you want to take that route.
    About Mystery Chlorine Loss:
    The most common identified causes of 'mystery' chlorine loss include:
    1. Unrecognized algae or bacterial growth, like mustard algae deposits or water mold (in light fixtures, etc)
    2. Prior use of a bromide product for mustard algae, or just about any product made by United Chemicals
    3. Low CYA, due to an earlier algae / biofilm bloom.
    4. Unrecognized heavy bather 'load', such as REALLY oily swimmers, or swimmers with full bladders.
    5. Regular use of algaecides.
    Fertilizer will not affect chlorine use EXCEPT by helping to fuel algae or bacterial growth, as in #1 above.
    My next-door neighbor has a summer "pool bathroom" that's outdoors, sort of, but built into the house. They have to winterize it, of course, shutting off the water and filling it with pool anti-freeze every fall. No idea what it cost.
    We don't but in an emergency it's just steps across a tile floor to bathroom off the kitchen--and it's a rough tile we put deliberately put in because it isn't deadly when wet.
    Plus, after an hour, we get kids out.
    mary jo is offline Subscriber Thread Analyst mary jo 0
    Aug 2014
    Batavia, IL
    @watermom- Indeed a dead body is the ultimate ick factor. Sure took my mind off of pee in the pool…
    so today's stats:
    Yesterday pool stayed at FC30 most of the day, dipping down to FC29 that evening.
    I added 1/2 jug of bleach and re-tested @10:00pm FC=31 CC=2.5
    This morning tested @ 7:15 FC=30 CC=2.0
    I'm not sure what else to clean! I fear we are approaching the end of the flow chart, and the dreaded "d" work (drain) is coming up….
    15K gal, 15x30 rectangular, in-ground, vinyl liner, Pentair ¾ HP Whisperflo on 24/7, Pentair Cartridge Filter(CCP240), Heater (gas), Automatic Pool Cover
    Jul 2013
    Northern Illinois
    NO! Don't be discouraged.
    FC numbers are looking good, especially with the very sunny morning today and taking the measurements at 7:15. Your CC is down to 2 so it is showing progress... albeit slow... but maybe you found the culprit in the light niches, filters, Nature2, or somewhere.
    Hang in there! Besides, you have a vinyl liner so "draining" is not a realistic option.
    BigDave's Avatar
    I'm not about to suggest that you drain. It looks like you are down to normal chlorine usage rates and the CC seems to be creeping down in spite of the cloudy skies.
    FormerBromineUser's post reminded me: You did remove the Nature 2 cartridge, yes?
    Aug 2014
    Batavia, IL
    It turns out the pool guys removed the cartridge- either at last year's closing or this year's opening. The vessel is empty and clean.
    OK- I wanted to add one more thing: my husband- who loves water but is pool illiterate- noticed "an extra hole" in the side of the pool while he was cleaning the light fixtures. I told him it was a dedicated return jet that the pool installer added assuming that we were going to go with the Legend's automatic vacuum system (an extra $1000). So the return jet was never used. Is this something that needs to be cleaned/maintained? I didn't think so since the other returns don't, but wanted to mention it just in case. I'm going to brush everything down today.
    BigDave's Avatar
    That extra return line is a place where "stuff" can grow and hide. is the other end of that line connected to anything or just capped off?
    Aug 2014
    Batavia, IL
    It must be connected because water comes out of it constantly- however, the pressure is lower than the other returns. It doesn't have a directional attachment on it- literally a 3" threaded opening.
    Jul 2013
    Northern Illinois
    Can you reduce the flow to your returns and increase the flow at this extra line? If so, do it for an hour or so to really force the shock level water in there. You would do the same thing for other water features: fountains, slides, etc. periodically, and especially at high CL levels.
  1. Clear Pool but cannot maintain free chlorine level?
    By Mr.Mooks in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-20-2011, 07:47 PM
  2. high chlorine, but crystal clear!
    By katydid in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-20-2011, 08:14 AM
  3. OK It's clear now what do I need to do?
    By joanie109 in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 08-19-2006, 04:46 PM
  4. Clear solar cover options? Magni Clear?
    By PoBoy in forum Pool Equipment & Operations
    Last Post: 07-10-2006, 11:01 AM
  5. Pure and Clear SWG
    By superjet in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-23-2006, 11:30 AM
