Results 1 to 10 of 89
Thread: Iron in water source
    BigDave's Avatar
    Default Re: Iron in water source
    I'm concerned that the filter is not working properly. As FormerBromineUser suggests, you can add DE to a sand filter to get it to catch smaller particles. You can test the filter with some DE as described in this link: http://pool9.net/de-test/. please do as it sounds like your filter is not working correctly.
    Aug 2014
    Virginia
    I will get the DE and try it. I've been concerned that the filter is not working correctly also. As I mentioned I had the sand replaced when I had to replace the liner. Was something done wrong or any idea what it could be? Right now have towels is both baskets. Catching lots of mineral. Rinsing and repeating. Probably just entertaining myself as it would probably take a month of Sundays. Was hoping the reduced flow would allow sand to begin to catch something. Flow still strong however. Please understand my frustration is with my pool, I appreciate all the time you, FormerBromideUser and PoolDoc have given this. I've had a pool 15+ years and never had to deal with a metal problem before. Wow!!!
    22,000 gal. 30' round IG, vinyl liner, sand filter, 1 HP pump, BBB method
    Taylor K2006c & K1000
    Aug 2014
    Virginia
    2/3 cup DE increased pressure 1 - 2 psi
    pH 7.2, FC 5
    Metal in solution, water opaque green.
    Still doing 1 cup polyquat every other day.
    Guess it's time to begin the cal-hypo again?
    BigDave's Avatar
    Forgive me for asking, but, why 1 C polyquat every other day? FC of 5 for CYA 50 should be fine for algae control.
    How did the pH get from 8.0 to 7.2? If you used MA, did you backwash first? How did backwash look?
    CC 0.0?
    Completely opaque or cloudy? Are orange particles gone?
    Is DE still in filter?
    Aug 2014
    Virginia
    Wondered myself but adding polyquat per PoolDoc's origin post to me.
    pH was 8.
    Backwashed, mostly milky white. Got baseline pressure.
    Added DE 1/3 at a time. Total 2/3 cup raised psi 1-2
    Used MA to lower pH
    Very cloudy, not quite opaque. No particles.
    DE is in system, added after backwash.
    Jul 2013
    Northern Illinois
    CC reading?
    While BigDave is thinking, make a mental note about DE. It should work well for you in removing iron. It also is very good on an on-going basis to filter out smaller particles in sand filters. You just have to remember to add 2/3C after each backwash.
    Aug 2014
    Virginia
    Will do.
    After 2 days and 2+ inches of rain I thought I better test all with 2006c kit.
    Currently:
    pH 7.2
    FC 1.0
    CC 0.4
    TA 50
    Ca hardness 160
    Virginia
    CC 0.0?
    I've read posts by Ben that said polyquat also acts as a clarifier, so my guess is that's it's purpose here.
    Jul 2013
    Northern Illinois
    While waiting for an answer from someone more knowledgable than me, get some cal-hypo in there pronto!!!!
    FC is WAY too low at 1.0.
    Keep an eye on your filter pressure.
    Aug 2014
    Virginia
    OK, just added 1 cal hypo to each skimmer. Will watch pressure. Do not plan to backwash until pressure increases.
  1. Iron In My Water
    By Phenom300 in forum -- Subscriber Posts --
    Last Post: 08-16-2014, 09:18 PM
  2. Iron out to treat iron and tea colored water
    By Fornetti in forum --cleanup--
    Last Post: 07-02-2013, 03:56 AM
  3. Well Water very High Iron
    By meadsrm in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-05-2012, 03:58 PM
  4. New Pool Owner With High Iron Manually Removing Iron
    By labdi01 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-18-2010, 03:56 PM
  5. Aerating Water to Get Rid of Iron
    By smallpooldad in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-27-2006, 10:59 AM
