Thread: Ortega valve repair
    Jul 2014
    CA
    Default Ortega valve repair
    Hi,
    I'm not that familiar with pools, but I'm a savvy DIY'er with plumbing experience. My dad past away a few years ago and so I've been taking care of my Mom's pool with the help of a pool maintenance guy. He told me that one of the Ortega valves (the one on the return side that sends the return water to either the pool or spa) didn't seem to be working. He said there was some air in the lines and when he switched the valve, nothing seemed to happen.
    Now, the valves haven't been turned more than once or twice in the last 5 years. I went to a local pool supply house and bought the inside parts to the Ortega valve - it seemed simple enough. But the pool maintenance guy said he didn't usually replace individual parts - he usually just bought an entire new valve, pulled the stem/valve assembly out and replaced it. Certainly less time to do that but a little higher in costs.
    Anyway, he's been procrastinating replacing the parts. I don't know if he's not confident that he can put the new parts in right or not. So I'm trying to decide if I should do it myself. I'm certain I can pull the cap and replace the diverter and stem. My concern is opening the valve and exposing it to air (of course the pump will be off when I do this.) Logically, to me, there shouldn't be an issue - since it's on the return side, I would expect that the water from the pump would continue to push water out the Ortega valve and the air in the line would simply be pushed out once it reached the pool or spa. Am I missing anything here?
    Thx
    Ron
    Default Re: Ortega valve repair
    I'm not entirely clear on what your question is -- it seems to be, "Can I fix this myself?".
    If so, the answer is "Probably, and if worse comes to worst, with plumbing experience you can always replace the Ortega valve with 1 or 2 ball valves."
    You also seem to be asking if a leak on the pump discharge side will leak water, rather than suck air. If so, then the answer is, "Yes, you are correct.".
    . . . membership updated.
    Jul 2014
    CA
    My question reaaly was if I can open the Ortega valve (thereby letting some air in) and close it back up without any adverse effects.
    Ron
    There's always the possibility that you're the victim of some totally weird piping that would result in problems if you open the valve . . . but NORMALLY it should be not be a problem.
  1. Need drawing of two position slide valve handle for nautilus backwash valve
    By Rgschell in forum Pool Equipment & Operations
    Last Post: 05-26-2014, 05:51 PM
  2. Plumbing repair - is this valve needed?
    By pfp-az in forum In-Ground Pool Construction and Repair
    Last Post: 03-28-2012, 02:52 PM
  3. Waterco F600 top mount multiport valve sand filter - removing the valve
    By wojie24 in forum Pool Equipment & Operations
    Last Post: 10-29-2011, 11:41 PM
  4. Push / Pull Backwash Valve Repair
    By jskins2000 in forum Pool Equipment & Operations
    Last Post: 09-08-2011, 03:19 PM
  5. multiport valve repair
    By curlysue121350@yahoo.com in forum Above-Ground Pool Construction & Repair
    Last Post: 07-23-2006, 10:08 PM
