Thread: foggy pool after adding too much copper sulfat(cuso4)
    hmasenger Guest
    Unhappy foggy pool after adding too much copper sulfat(cuso4)
    hi all
    i have a serious problem after adding 1 kg copper sulfate (cuso4) to 100,000 liters of water .the water becomes gray and foggy !! pleas help if you know how i can solve this problem.is there a way to oxidize or decrease the amount of CUSO4?
    it should be mentioned that, the sand filter is new working fine .
    don't you think AlSO4 would help ?
    best regards
    Default Re: foggy pool after adding too much copper sulfat(cuso4)
    Sorry. I'm not even going to try. We have a hard enough time trying to help people in the Euro market, because they cannot use the products we recommend. Trying to figure out how you can solve your problem in Iran, with no access to either US or Euro products is an exercise in futility. You're welcome to browse through the PoolForum and PoolSolution, work out the principles of pool care, and then figure out how you can apply them with the products you DO have available.
    I will point out that CuSO4 would not itself cause gray and cloudy water. More likely, it's the lack of an effective oxidizer. Aluminum sulfate is of some value in removing copper, but it's a twitchy chemical. When it's used in potable water treatment, water paramenters are carefully determined in advance with "jar testing", and then adjusted to match BEFORE dosing with alum. Trying to use it in a pool will have unpredictable results. If you want to use it, I'd strongly recommend using the very 'old-school' method of dosing upstream of the sand filter, to try to produce a 'floc' coating on the filter. BUT, the success of this depends on relatively low flows through the sand filter. If you are using a modern filter with unrealistic flow ratings and an over-sized pump, you're rather likely to just drive the alum floc out into the pool, making things worse.
    Good luck!
    Just had a thought.
    I've been told that TroubleFreePool.com has moderators that like trying to puzzle out how to manage pools in remote locations. You might want to register there, and see if someone will take your pool on as a personal project. For the most part, they follow the methods of pool care that I developed.
    hmasenger Guest
    Tnx a lot ben
    I am really glad that i have found a forume which people respect eachothers comments and situations so tring to help .
    I will consider your guidence and soon i will share my experienc.
    Best regards.
  1. Help with foggy pool
    By Watermom in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-01-2014, 02:08 PM
  2. Newbie with a 21' AG pool, wondering about copper
    By The Frant in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-07-2014, 01:40 PM
  3. My First Pool - 0.2 ppm copper reported
    By tim5055 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 04-06-2014, 02:13 PM
  4. Huge amounts of copper in the pool
    By haule in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-13-2013, 10:40 PM
  5. Copper in the Pool
    By scv123 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 08-21-2012, 05:05 PM
