Some 'safe' MA's have detergents or other addititives, making them NOT-safe for your pool.
						Thanks everyone! I vacuumed the pool and while doing that I noticed some more algae... not much. I brushed like crazy and then went swimming later.
My birthday suit doesn't fade! LOL
Kept an eye on it all weekend, and so far the algae did not return. I will inspect closer again when I get home this afternoon, but maybe I have beat it back for now.
I need to take a look at the MA that I bought and see what is "exactly" in it. I will post here and see if it needs to get returned for regular MA.
I'd like to borate the pool ASAP. Any suggestions on how much MA to add to start bringing my TA down before doing so? Or as you said PoolDoc I really don't need to worry about it?
5.2k gal 16' x 48" Summer Escapes AG, Intex 2650 Sand Filter. PF=23
Re MA: check the MSDS; it's likely that will reveal whether there are problematic additives. However, the presence of even the slightest 'sudsing' or soapy bubbles in the MA solution is sufficient reason to keep it away -- far away -- from your pool.
I wouldn't worry about the TA. Just add the borax, and then add MA till your pH is normal. If you have a K2006, you can use the acid demand test to quantify how much MA is needed at any given point. However, I think the "poolcalculator.com" will also give you a useful indication. I would STRONGLY recommend that you (a) use PLAIN 31% MA and (b) never use more than 1/2 of the dose you think you need to fully correct. You can always add more later.
If you haven't already, do read the MA safe handling guide => http://pool9.net/ma/
						Here's the MA that I have... http://www.certol.com/AcidMagicHome.aspx
I'm still looking for what's in it... Should I exchange this for the real stuff?
http://www.certol.com/pdf/Industrial...agic%20SDS.pdf
Shows only - The User Friendly Muriatic Acid!™*
Chemical Name CAS No. Weight-%
Hydrochloric Acid 7647-01-0 Proprietary
The specific chemical identity of this composition is being withheld as a trade secret.
Yes. Mystery ingredients can cause very, very real problems with your pool.Should I exchange this for the real stuff?
						Oh boy... guess I'll have to exchange it for the real deal... I need another gallon anyways for my borate operations. LOL
So this morning... the bane of my existence has returned. I had small amounts of algae on the bottom of the pool near the walls. Basically where the seam is on these intex type pools...
I'm really at a loss here... FC level is still coming down from 30. I'm at 12. I have still kept adding bleach just to be on the safe side. Other folks are telling me that it may not be algae that it could be pollen.
We have had lots of rain, maybe it's washing off the surrounding trees and collecting on the bottom, I do not know.
I had to drain off waste during a bad rain the other night, so I'm betting my CYA is down to around 30 now. I am tempted to get some powdered shock and see if that will help?
Otherwise, I'm just going to keep my FC high, and keep brushing...
You need to stop thinking of pool chemicals by their brands or descriptions, and start thinking of them by the chemical they contain. "Powdered shock" could be an excellent choice OR a terrible one, depending on which CHEMICAL is present in the "powdered shock" you have in mind. Neither we, nor you, know whether that product is good or bad for your pool, till we know what's actually in it.
Pool store operators and especially, pool chemical makers, really, really want to prevent you from getting involved "in the complications of pool chemicals and their effects": they want you to let them "make it easy for you". And honestly, if they actually did just that, PoolForum would be unnecessary. The problem is, they don't. The reasons are complex and pool store operators are themselves somewhat the victims of misinformation and misdirection from the pool chemical makers. But the bottom line is, the primary purpose of pool brands is to (a) sell you cheap chemicals expensively and (b) sell you rarely needed but high margin chemicals routinely.
Back to your pool: dusty debris on the bottom could be any of the following: mustard algae, dead algae (either green or mustard), sand from your filter, blown in or tracked in dirt or pollen.
You can probably rule some of these in or out yourself:
+ No dusty wind? Then, no blown-in dirt.
+ No pollen on flat surfaces outside? Then, no bulk pollen in pool.
+ No body tracking in dirt or sand? Then, no tracked-in dirt.
+ No yellowish-green somewhat uniform coating on your pool walls and floor, prior to accumulations of powder? Then, the dust is is not dead mustard algae.
+ Dirt does not feel gritty between your fingers, when you pinch a bit of it up? Then it's not sand.
PoolDoc / Ben
						Is there a recommended dry shock? Just curious. I would never visit the pool store for chems BTW. I would use Walmart because at least there I won't be bothered by pesky pool store sales people. LOLSorry, I didn't mean to make you fret. I'm just frustrated. I will most likely pickup MORE walmart bleach since it does seem to be more potent than the Aldi bleach I was previously using and bring the pool up to SHOCK level... again...
To answer your questions:
Well, it's been windy, but during our torrential downpours.
Noticeable pollen was early this spring. I have not noticed it on vehicles or other surfaces around my house. However, we have 2 acres and lots of trees. It could be wash off the trees, no?
No one has been in the pool since Saturday night, and I had vacuumed the pool Sunday.
Then, the dust is is not dead mustard algae. - Well on the floor near the seams where the floor meets the walls.
Pool is too deep for me to try that, can't lean over and grab some, but it is NOT disturbed by my skimmer pole, but is brushed away with the pool brush.
						Well, I brushed this morning and it turned to a green cloud... but... what you say makes sense, and I say this because I recently changed where my return was facing. They recommend you face it to make the flow of water go clockwise assuming the skimmer is 6'oclock, but I found if I kept it this way, skimming was reduced. So I've had it facing down... which would cause anything coming back in, sand or otherwise... to be spread out to the edges of the pool floor. Make sense?
I'll check when I get home, and try to inspect the suspect more closely. LOL
Thanks for all your help!!!
