After 20 years of having a sparkling pool, we now have what the pool shop is calling a chlorine lock. Never heard of this before and after 25lbs of shock being dumped in out pool over the last 7 days, we really do not think the pool shop knows what to do. After reading about chlorine locks on this website, we went directly to the store and bought 6 gallons of bleach and put it in last night at dusk, waited an hour and tested (with the dreaded test strips that I am learning is absolutely the wrong way to test!) and all looked good. Tested again this morning at dawn and no chlorine, no free chlorine, and no stabilizer (no sure what that means either). The water is cloudy, is not green, but noticing algea on the string that holds thermometer and on ladder steps. Our pool is 23000 gallon, vinyl lined, in ground pool. AND, after fiddling with the filter, checking chlorine tabs over and over, I managed to break the auto chlorinator which was newly installed in April of this year. Now it is leaking all over the place when the filter comes on. Ugh!
and the results were: chlorine 0, free chlorine 0, and ph 7.4. If I understand your directions clearly, I should continue to add 2 gallons of bleach every night until the testing the next morning show that the water is holding the chlorine throughout the night. Is this correct? I hope to have the good kind of test kit today. Wish me luck on my quest! Thank you for your guidance!
