Results 1 to 10 of 23
Thread: Plaster is like Sandpaper
    Jul 2014
    Oklahoma
    Default Plaster is like Sandpaper
    Hello All,
    So far I have done everything requested from newbies. I have subscribed, liked you on Facebook, and filled out the pool form and ordered the Taylor K-2006. Now I need your help.
    This is the fourth year for our pool. It's been trouble free until this year. All of a sudden we have a very rough surface which leaves our feet sore and abraded. After reading many threads on your web site I think it is calcium scale. I don't know how to get a sample of it so I can put it in vinegar (??).
    The guy I use to open and close said to put sodium bicarbonate in it to raise the alkalinity up to the max and then the next day add 2 gallons of muriatic acid to bring the pH back down and then use a wire brush on it. Then repeat this process weekly until it is gone. As little as I know about it that just doesn't seem right.
    The pH has always been on the higher end 7.8 and above but I didn't worry too much about it. Now, I think that is the cause of my problem. I just ordered the K-2006 today so I went to the pool store with my sample and here is what they came up with:
    pH: 7.8
    Calcium: 309
    Alkalinity: 90
    Chlorine: 1.65
    CYA: 79
    Salt: 3100 (Pentair IC40)
    Thank you in advance.
    Default Re: Plaster is like Sandpaper
    I'm assuming that you have a concrete pool?
    (Hopefully, nobody would tell you to use a wire brush on any other type of pool! If they did, they are truly a pool idiot!)
    If you have a vinyl or FG pool, it has to be scale; there's just about no other way for the surface to get rough like you've described. Removing the scale from those pool is pretty easy.
    If you have a concrete pool, however, it's harder. The problem is the scale is usually calcium carbonate . . . and so is at least some of your pool's surface.
    But if it's a plaster pool (Marcite, marble aggregate + white cement), then the other possibility is that it's the opposite of scale; the roughness is the result of low pH for an extended period (or very low pH for a short period) causing the surface to erode.
    You can get a pretty good indicator of which it is by examining non-concrete / plaster submerged surfaces. Scale will usually form on metal and tile surfaces as well as on the pool surface. Erosion will be confined to the pool surface. Also scale will be above the original surface; corrosion will penetrate below the original surface.
    Post what you find. It will help me if you fill out the pool equipment form, too: http://pool9.net/pf-equip-form
    Jul 2014
    Oklahoma
    Thanks for the speedy response PoolDoc. I did fill out the pool form, should I do it again?
    The pool is a gray plaster. The grit is not on any tile or plastic return surfaces. The pH has never been low. I don't know if it was low over the winter when the cover was on it.
    25k gal 22 x 34 concrete free-form (oval) IG pool; city water; SWCG, Jandy CV460 cartridge, Jandy SHPF pump, 12hr, bubbler. PF=4.8
    For some reason, your user name was omitted, but I found it via email address.
    If there's no grit on the tile or plastics, you need to take a look underwater with a mask or goggles, and see if it's raised or depressed.
    Tell me about the "bubbler" -- what is it, where is it, when does it run . . . and most important, did you maintain a normal (<7.8) pH while it ran?
    I'm afraid I may know what happened; telling you my suspicions may help you confirm or deny them:
    1. Your 'bubbler' -- presumably some sort of continuous aeration -- ran quite a bit.
    2. Because you were a conscientious pool owner, you maintained a proper pH . . . but you didn't check TA all that often.
    3. Because the pool industry -- except for my site and a couple of derivative sites -- does not understand how carbonate alkalinity works in pools, no one warned you what happens if you (a) aerate and (b) maintain the pH. This page -- http://pool9.net/alk-step/ -- explains what happens.
    4. You ended up running a pool with VERY low carbonate alkalinity, which eroded your plaster, even though the pH was normal.
    5. Consequently, you ended up, not with scale, but with corroded plaster.
    An inspection from 6" away with goggles will tell. It will be easier if you do so early or late in the day, so the light striking the plaster at an angle, rather than from directly overhead.
    Jul 2014
    Oklahoma
    I looked at the plaster with goggles and the plaster is pitted but also rough like sandpaper. I took a 1" putty knife to a small area of plaster and I was able to make it smooth but obviously the pits are still there.
    The 2 bubblers are in the shallow tanning ledge and run all the time for the "bubbling brook" effect. The pH is in the high range most of the time.
    Yes.
    Yes.
    Yes.
    I think the alkalinity readings were within range most of the time.
    It almost seems as though I have both since I am able to scrape the grit off. Is that possible? Chemically speaking.
    An inspection from 6" away with goggles will tell. It will be easier if you do so early or late in the day, so the light striking the plaster at an angle, rather than from directly overhead.[/QUOTE]
    I read the article at the link you posted about lowering alkalinity but it seems like my numbers are all within the satisfactory range so right now I'm sort of confused. I plugged my numbers into the saturation index and came up with +0.5. If the pool readings taken yesterday are correct and the saturation index is correct and taken with the article about lowering alkalinity, now I'm really confused!
    So my questions are:
    1.If my plaster is damaged, what can be done, if anything?
    2.What do I need to do to get my pool in balance? Based on the SI.
    3.Is there a way to remove the sandpaper feel chemically? The pool is too big to do with a 1" putty knife.
    Again, thank you for your assistance.
    Quote Originally Posted by Mikes Pool View Post
    Unfortunately, yes. When you erode the surface of the plaster, what's left is much weaker and even friable.
    The alk-step article explains what has ALREADY happened to your pool, in an extreme and uncontrolled degree. I was NOT telling you what you need to do!
    I first ran into this problem, years ago on pools with UV ozonation and venturi injection of a little ozone and a lot of air. What happens is the aeration from the venturi strips all the carbonic acid (a component of carbonate alkalinity) and thus drives the pH up. If you neglect your pool, and allow the pH to remain high . . . there's no damage. But if you are conscientious, and adjust the pH, you consume remaining carbonate alkalinity by converting it to new carbonic acid. And then the process repeats.
    I'm sure, with the popularity of infinity edges, waterfalls, and yes, bubblers . . . this is a very common problem. It's approaching 20 years since I first published an explanation of this. 10,000's of pool users have PROVED that I was correct, and Chem_Geek has published an extremely comprehensive spreadsheet that displays the whole cycle in excruciatingly comprehensive and detailed fashion. But because the pool industry as a whole has never been willing to acknowledge the fundamental errors in the way they've dealt with carbonate alkalinity, the problem continues, victimizing both pool owners and pool builders, who've been mis-instructed.
    Unfortunately, the only fix for having REMOVED the top layer of your plaster is to replace it, with either a replaster job, or by refinishing with epoxy or a lesser pool paint.
    I have vague recollections of having heard of people sanding pools -- it would be tedious, but if your remaining plaster is thick enough, it could probably be done using flexible diamond disks. I have had some diamond disks that would work, but those pads are no longer sold. I'm sure there's something out there, but I have no idea how much it would cost or how long it would take.
    Sorry!
  1. Vinyl liner feels like and looks like sandpaper
    By brianp in forum Dealing with Algae & Slime
    Last Post: 05-25-2014, 05:30 PM
  2. sides of pool feel like sandpaper
    By mkimberlycarter in forum Dealing with Alkalinity and Calcium
    Last Post: 05-12-2014, 03:41 PM
  3. Plaster repair: white blobs in minor cracks. Time to re-plaster or paint?
    By wpicot in forum In-Ground Pool Construction and Repair
    Last Post: 05-22-2012, 07:24 PM
  4. Vinyl liner feels like sandpaper
    By Texas247 in forum Dealing with Alkalinity and Calcium
    Last Post: 04-14-2012, 08:30 AM
  5. Smooth plaster turned into sandpaper
    By FatKid44 in forum In-Ground Pool Construction and Repair
    Last Post: 05-09-2006, 01:09 AM
