Results 1 to 10 of 11
Thread: 12 x 30 pool - Super Easy questions
    Jul 2014
    Default Re: 12 x 30 pool - Super Easy questions
    I too have had sections of the bottom of my pool get bleached by dichlor. Will start with the bucket tonight so the bottom doesn't get any worse.
    Quote Originally Posted by sigep739 View Post
    The good news is I started adding dichlor last evening. pH has become more stubborn (before I got the dichlor, actually)... it wants to hover around 7.0. So not terrible -and I think I am going to conquer that.
    Anyway - my real issue is that the dichlor seemed to bleach the bottom of the liner where I dropped it in last night. I wasnt running the pump. SO I am probably a dummy all together. Should I be mixxing it with a bucket first - or just spreading it evenly as much as I can?
    Thanks!
    10 x 30 Intex pool
    OK. I'll add 'mix before using' notes to the SSR.
    @gabrieldaigle: Do you know how much you added at one time? Was your pump running at the time?
    Jul 2014
    Ben,
    I never put more than a half cup of Dichlor and usually spread it throughout the pool. It has led to bleach spots in multiple areas of the pool. Also I always have the pump running whenever I put any chemicals in the pool.
    10 x 30 Intex pool
  1. new user - Super-Simple pool chemistry for Intex questions
    By jab240 in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-01-2014, 05:48 PM
  2. Upgraded Intex Easy Set pool pump and now have questions....advice please!
    By KarenG3 in forum Intex-type Pool Setup & Operations
    Last Post: 05-15-2012, 11:10 PM
  3. Questions on changing to a 2 speed motor on a Hayward Super II pump
    By keastman in forum Pool Equipment & Operations
    Last Post: 05-01-2012, 01:10 AM
  4. Some easy questions, some harder ones too!
    By sock monkey in forum Pool Equipment & Operations
    Last Post: 06-12-2006, 09:12 AM
  5. NEW 18' metal frame easy set agp questions.
    By darenjones in forum Above-Ground Pool Construction & Repair
    Last Post: 06-03-2006, 04:46 PM
