Hello everyone, I need some advise please. We purchased an Intex 16x48 above ground pool Saturday. We started filling it Saturday night and Sunday morning it was full and the water was already green. It was a clear green where we could see the bottom but a heavy green tint. I got the chlorine to shock level and ran the pump. Monday, no change and the chlorine was still at 10. I tested the water and it said the PH was low and the hardness was low. On Monday I corrected all of that and the chlorine was still at 10..and the water was still green. I got frustrated and turned the pump off and decided to just leave it alone until Tuesday when I wasn't so annoyed. Tuesday morning the water was almost clear and the bottom of the pool was covered with a rust colored powder. It's not stained. I looked at the filter and it was completely covered in the rust colored stuff. Its not slippery or gooey so I was thinking it's not algae. Anyway, I had to drain the pool to about 1/3 filled because one of the legs was a little crooked. I haven't filled it back up because its raining and I want the ground to dry so it doesn't sink into the mud with the weight of the water. Does anyone have an idea about the rust colored powder? The vacuum doesn't catch it so when I run it the water just gets cloudy and eventually settles back to the bottom. I was considering putting a sock on it so it would catch some smaller things. Could this be metal in the water? I have city water and not well water. I purchased some metal out to throw in there once I get it filled up. At a loss as to what is going on because all of my levels were right.
