Thread: Using bleach in a Intex pool with coffee-brown water
    Jul 2014
    Default Using bleach in a Intex pool with coffee-brown water
    If I use bleach with the Borax,will it hurt my Intex pool. I have a 22 x 52 round pool and I'm having trouble with my pool water turning coffee brown. I drained it and am going to begin to fill it up again. Im just not sure what chemicals to start with.
    BigDave's Avatar
    Default Re: Using bleach in a Intex pool
    Bleach is fine. Many members here use it.
    "Coffee brown" makes me think you fill with well water. Do you? Before you refill, is the fill water source the same as the house water source? If you have a ceramic toilet, how does the inside of the tank look?
    What Dave said.
    The only time I've seen pool water be truly coffee brown was when it was filled with manganese contaminated well water. What a mess!
    . . . membership updated.
    Jul 2014
    Default Freddy's Pool -- Starting an Intex -- Water turned brown
    I followed the 1st & 2nd steps of the SS Recipe but stopped filling my pool because the water turned brown. I tested the tap water with a 6 way strip and the hardness was 100 the bromine was 1-2 the PH was 8.4 the alkalinity was 240 and the cyanuricacid was 30-50. I need help.
    Last edited by PoolDoc; 07-04-2014 at 12:22 PM. Reason: blend threads merged from posts tagged onto the SSR
  1. Brown water inside Intex filter
    By Robryan29 in forum Pool Equipment & Operations
    Last Post: 07-12-2014, 12:03 AM
  2. brown water in new pool
    By brown and sad in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-08-2014, 01:13 AM
  3. New Pool Owner 15X42 Intex Metal Frame - very rusty brown well water
    By Heidi B in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-03-2012, 01:41 PM
  4. brown water from well in pool
    By Hanna in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-04-2011, 08:13 AM
  5. Coffee
    By Jeffski in forum General Interest
    Last Post: 06-20-2007, 10:41 AM
