Thread: variable speed pump
    Jun 2014
    FL
    Default variable speed pump
    Hey everyone I'm new to the forum. I just bought a house with a 36x18ft inground pool. It has a 3hp Pentair Intelliflo variable speed pump. Right now the pump is set to run 2450 rpm for 10 hours. My question is how long and what speed should I run this pump at. The pool place told me to run it at 2500 for about 4 hours then bring it down to 1500 for 4 hours. With the way the pump is set up it is doing a great job, however, if I could reduce my electric bill by lowering the RPMs that would be ideal. At 2450 Im using 900 watts and at 1500 I use about 300 so theres a big difference between the two speeds. What are your thoughts on how to set this pump. Thank you in advance for any help. By the way my pool is 3.5ft deep at one end and 8ft at the other.
    18 x 36 IG pool with Pentair Intelliflo VS pump
    mas985's Avatar
    Pleasanton, CA
    Default Re: variable speed pump
    1000 RPM is the most efficient for the Intelliflo. I would try that for 4-6 hours and see how it does. You may need to up the RPM a little to help with skimming.
    If you have pool cleaner, you may need the higher speeds for that as well.
    Mark
  1. New variable speed pump loosing prime at low speed
    By lucas2 in forum Pool Equipment & Operations
    Last Post: 07-23-2013, 11:09 PM
  2. If you run a variable-speed pump at half-speed, does the turnover rate double?
    By famousdavis in forum Pool Equipment & Operations
    Last Post: 07-25-2012, 01:22 PM
  3. what speed on a variable pump?
    By bomberchamp in forum Pool Equipment & Operations
    Last Post: 04-11-2012, 11:53 AM
  4. variable speed pump
    By bradc344 in forum Pool Equipment & Operations
    Last Post: 01-16-2012, 09:18 AM
  5. Variable speed pump upgrade
    By kmh in forum Pool Equipment & Operations
    Last Post: 10-17-2011, 08:33 AM
