Results 1 to 9 of 9
Thread: Milky blue water after Phos-Free
    Default Re: Milky blue water after Phos-Free
    OK.
    That's different. Immediate clouding after adding HTH is almost certainly calcium carbonate precipitation.
    1. FIRST, make completely SURE that there is no feeder, mineral device or other chemical or treatment gadget or gizmo anywhere between the skimmer and the filter.
    2. SECOND, make SURE that there is NOTHING the skimmer basket.
    3. THIRD, add HTH directly to the skimmer, but in 1/4 the normal dose. Watch the pool return, to make sure there's no cloud going back into the pool from the HTH. So long as there's not, add the rest of your doses to the skimmer, 1/4 dose at a time, waiting at least 15 minutes between doses.
    4. Watch the Taylor vids: http://pool9.net/tk-guide . When you get the kit, be careful to get an accurate TA and CH test result. Ignore the booklet and blue wheel.
    Good luck!
    Jun 2014
    Ontario, Canada
    I just want to close the loop on this case of milky water. In the end, it was confirmed that PhosFree did NOT cause the milky water - it was the dry chlorine - HTH - causing calcium carbonate precipitation, as predicted by PoolDoc / Ben. So, I didn't add any clarifiers, I'm back to liquid chlorine, and have a crystal clear pool again. Thanks so much for sharing your expertise!
    100,000 litre / 26,000 us gal vinyl pool - Pentair Clean&Clear cartridge filter- 1 hp Hayward pump running 12 hrs/day
    Thanks for the follow up!
  1. Milky water
    By Spideracohen in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-21-2014, 03:23 PM
  2. Milky cloudy water - concrete dust? At a loss.
    By lady.k in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-02-2013, 11:38 AM
  3. My Deep Blue Water is Now a Light Green-Blue???
    By Spike in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 01-25-2012, 02:01 PM
  4. Milky Water and low PH
    By newbie2pools in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-19-2008, 05:11 PM
  5. milky white water I suspect from cal hypo any thoughts
    By mspool in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-12-2006, 07:42 PM
