Results 1 to 10 of 16
Thread: cloudy darkish water
    Default Re: cloudy darkish water
    Have you kept your chlorine at shock level for a period of time until the algae is dead? If not, then that is why you continue to have algae. With a CYA of 50ppm, your shock level will be about 15ppm to kill it.
    But, do the bucket test first before shocking the pool.
    May 2011
    centralcalifornia
    Sorry, been out for a while. I have not done the bucket test yet, but this is whta has happenned. I thre in some potassium peroxymonosulfate (fresh n clear) 3 lbs and water cleared within a day and a night. Stayed clear for about 3 days and now greenish again. All other values are same, chlorine at 6ppm. Anyway, I am being told that problem is sand filter cus it doesn't filter small microns and that instead of using diatomaceuous earth I need to use cellulose fiber, a de altenative because it filters smaller microns...any comments on this??
    Without getting into it, the ONLY reason for cellulose is as a replacement for DE in DE filters. You have a sand filter; we're using the DE primarily as a test. The cellulose can NOT be used for that purpose (and it's not all that good as a DE replacement, either!).
    We would have told you not to use the monopersulfate . . . but the result you got is very surprising. MPS would have had NO effect on algae. I am completely puzzled by what could make your pool green, be cleared up by MPS, and then return to green. I'm going to see if Chem_Geek has any ideas.
    Meanwhile, please take your kit and do a COMPLETE set of tests on your pool: FC, CC, pH, TA, CH, and CYA and report those.
    Also, turn your pump on and leave it on.
    Finally, when you need to backwash, please note the color of the backwash discharge.
    Thanks,
    MPS is acidic so if the green, or at least some of it, is from metals then the green may have gone away when the pH dropped and then come back when the pH rose again.
    If there is algae creating cloudiness, then just maintaining a normal FC/CYA level will not get rid of it because if the water is cloudy and if that is from algae then the algae is clumped enough that it can still grow inside the clumps faster than chlorine can kill it from the outside. That's why we shock the pool in this situation to raise and maintain a higher FC/CYA level to completely kill off the algae.
    What I suggest you do is first lower the pH to at least 7.2 (but not below 7.0) and see if the green lightens at all. Then shock with chlorine to 20 ppm FC (assuming your CYA is really 50 ppm) and maintain that level which means adding chlorine multiple times during the day (or at least at morning and early evening if no one is around during the day). If it gets green again, that would be from the chlorine raising the pH. Don't worry about that. Just hold the high chlorine level and filter 24/7 (using both the skimmer and floor drain) to get rid of the cloudiness. Once you get to a clear green then you can deal with the metals.
    Is your pool surface blue? If so, then you may have iron in the water (that's not uncommon in well water) since yellow+blue looks like green. Otherwise, green is usually from copper. That usually comes from use of a copper algaecide and is not usually in well water.
    Ahh! I forgot that it was so acidic. It's been a LONG time since I messed with MPS.
    Thanks, Chem_Geek.
    The equivalent amount of oxidizing power as 1 ppm FC when added as MPS (6.7 ounces weight per 10,000 gallons) has the same acid effect (after usage/consumption) as 2.5 ounces of full-strength Muriatic Acid (31.45% Hydrochloric Acid) per 10,000 gallons. It's actually somewhat more acidic for equivalent FC than Trichlor.
    May 2011
    centralcalifornia
    Ok. FC is 7. CC is 0. TA IS 80, CH is 350. CYA is 55. Ph is between 7.6 and 7.8
    I did throw in some algaecide last night and now water is milky white and can see the bottom of deep side, thiugh not clearly. The stuff is called skill-it from biodex. Before I threw the algaecide s the water was still green despite running filter 24/7. I never tried the cellulose fiber and will be returning it.
    Been running filter and threw in some DE to where pump psi went from 7.5 at clean back wash to now 8.5 psi. I'm going to the store right now to get the stuff to do the metal test.
  1. cloudy water
    By dave198 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-21-2011, 10:56 AM
  2. Cloudy Water & Water Behind Liner
    By cschnurr in forum Dealing with Algae & Slime
    Last Post: 09-19-2007, 09:04 PM
  3. Cloudy Water - Don't know what to do next
    By tnrick in forum Dealing with Algae & Slime
    Last Post: 08-11-2006, 08:58 PM
  4. Cloudy water Help!!
    By kritter in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-08-2006, 10:18 AM
  5. cloudy water
    By slowtan in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-11-2006, 07:50 AM
