Hi all.
We're on our 2nd season with an 18'x48" Intex 'baloon type' AGP that got away from us over the winter and opened very badly. Lots of algae.
Before I go into details about what all chemicals we've thrown in and what our measurements are [or lack thereof], I have to question whether it's even worth it.
We've been at this for over 4 weeks and have spent more money on filters, supplies and chemicals than the $47.00 it would cost to simply drain, clean and refill, not to mention not being able to actually use the thing.
By haphazardly following advice from this site, we've managed to kill off most of the algae to the point the water was mostly clear, with just some greenish/brown dust piles on the bottom. The 'debris vacuum' the pool comes with is worthless on that, so I picked up a 1½" hose and vacuum head, and hooked it straight to the Intex pump/filter. It vacs up a little, but we quickly lose suction. I don't think the Intex pump is strong enough to draw through 25' of hose.
In the process of vacuuming from inside the pool, we stirred up all the bottom dust and made the water cloudy again. We also noticed that quite a bit of the dust was flowing right through the filter and back into the water.
So, the question at this stage is, should we keep on keepin' on, or drain the thing and start over? And should we buy a bigger pump? [such as http://smile.amazon.com/Swim-Time-NE...=1&*entries*=0 ]
The Intex pump seems to do the job as long as the algae is under control, but if it does get out of control, it fails miserably.
