I have a question about those little swimming bugs, i think they are called back swimmers. After i had my pool up for about 2 days (in the yard, no cement), these things showed up. I called leslie's and they advised me to shock, lower ph with muriatic acid, and use black algae killer. I did this (except I used hth algae guard 3x concentrate) and every bugs in the pool was dead. I vacuumed them up yesterday, and when I went check on the pool this morning. Surprise, they are back by the hundreds. Well, I have a formula for killing them, but how can i keep them out? I use hth chlorintating tablets. Have to keep chlorine at almost shock levels to kill em. My readings this morning are:
Chlorine: around 4 to 5
PH: around 7.6 to 7.8
Pool info:
Intex 22' x 52" Ultra Frame AGP.
~10,000 gallons
Vinyl pool with metal frame.
Krystal Clear Cartridge filter pump, 2,500 gph.
Installed 6-4-14 filled with city water.
Here are some pics of the bugs that keep coming back.
Thanks for the help!
  New pool owner solves severe backswimmer bug problem with quat algaecide
  Re: Hello everyone! New pool owner having severe bug problems!
